Re: [cgal-discuss] unique pointer to cgal::Polyhedron_3 objects created in loop
- To: <>
- Subject: Re: [cgal-discuss] unique pointer to cgal::Polyhedron_3 objects created in loop
- Date: Wed, 27 May 2015 19:35:48 +0200
- Organization: University of Bern
Dear Andreas,
Thanks a lot! Your hint at instantiation with 'new' solved the problem.
daniel
On Wednesday 27 May 2015 08.26:41 Andreas Fabri wrote:
> What you write would hold for any class.
> for(...){
> std::vector<int> V = FunctionThatCreatesAVector()
> std::cout << &v << std::endl;
> Your FunctionThatCreatesAVector()
> should create a vector<int> with new
> and then return the pointer.
> andreas
> On 27/05/2015 07:55, Daniel Abler wrote:
> > Dear List,
> > I would like to create a list of pointers to Polyhedron_3 objects
> > (created in a loop) for later meshing via Polyhedral_mesh_domain_3, as in
> > the following pseudocode:
> > struct K: public CGAL::Exact_predicates_inexact_constructions_kernel {};
> > typedef CGAL::Polyhedron_3<K> Polyhedron;
> > std::list<Polyhedron*> poly_pointer_list;
> > for (...)
> > Polyhedron cgalpoly =
> > FunctionThatCreatesCgalPolyhedronFromVTKPolyData;
> > poly_pointer_list.push_back(&cgalpoly);
> > The problem here is that &cgalpoly always points to the same address... I
> > suspect this has to do with the 'copy constructor' of Polyhedron_3 or my
> > 'FunctionToCreateCgalPolyhedronFromVTKPolyData'.
> > How can I make sure that each cgalpoly created in the loop is kept in
> > memory and can be addressed by an unique pointer?
> > Many thanks,
> > Daniel
- [cgal-discuss] unique pointer to cgal::Polyhedron_3 objects created in loop, Daniel Abler, 05/27/2015
- Re: [cgal-discuss] unique pointer to cgal::Polyhedron_3 objects created in loop, Andreas Fabri, 05/27/2015
- Re: [cgal-discuss] unique pointer to cgal::Polyhedron_3 objects created in loop, Daniel Abler, 05/27/2015
