- To:
- Subject: Re: [cgal-discuss] CGAL::linear_interpolation
- Date: Tue, 2 Jun 2015 15:12:41 +0200
Hi Andreas,
here is a small data set:I created a small region 10x10 with resolution 1m.
north: 10
south: 0
west: 0
east: 10
nsres: 1
ewres: 1
rows: 10
cols: 10
cells: 100
6.1492718|1.38340775|91.12609400
5.13390161|2.73835363|12.07604600
8.07245632|0.4525116|89.91016900
4.09978228|4.81470035|91.63207700
5.64333425|5.35229498|5.53118800
4.17097588|2.71770808|3.44402800
1.18859736|6.30061561|36.33730100
3.60237755|4.66005842|16.61935800
9.63803784|0.10443555|99.67707600
2.71315208|0.58555986|58.36077900
Some examples of query points (represented as 1m x 1m cell):
4.5|3.5||30.6767022751186
4.5|1.5||27.4545361650472
6.5|1.5||62.9808584320274
5.5|3.5||27.2998580089716
What I expected:
4.5|3.5||10.5043057804237
4.5|1.5||62.9320720752062
6.5|1.5||84.2197781468109
5.5|3.5||15.7523200829975
Expected results are based on GRASS GIS module v.surf.nnbathy, that uses nn-c library[1]. These results(v.surf.nnbathy) are pretty similar to results from ArcGIS (these results should be correct).
Best regards,
Adam
2015-05-28 10:15 GMT+02:00 Andreas Fabri <>:
Hi Adam,
can you provide us with a small data set, that demonstrates
what you say. Ideally something like < 10 input points and
a single query point, plus what you expect as result.
Best regards,
Andreas--
On 21/05/2015 18:37, Adam Laža wrote:
Hi all,
I use CGAL::linear_interpolation function in my GRASS GIS modul
v.surf.nn that provides natural neighbor interpolation for 2D scattered
data. Code works well, I write down the results into an output raster
map. But the output differs a lot from another outputs.
For same data I use GRASS GIS modul v.surf.nnbathy (this module uses
nn-c library) and ESRI ArcGIS tool Natural neighbor. Output of these
tools are identical. But the output of v.surf.nn using CGAL is
completely different.
Any idea what's going wrong?
Thanks in advance
Adam
ArcGIS output: http://oi60.tinypic.com/ou17c4.jpg
GRASS GIS (v.surf.nnbathy): http://oi60.tinypic.com/ml4jd5.jpg
GRASS GIS (v.surf.nn using CGAL): http://oi58.tinypic.com/208k9du.jpg
Code:
/* perform NN interpolation */
G_message(_("Computing..."));
/* triangulation */
Delaunay_triangulation T;
typedef CGAL::Data_access< std::map<Point, Coord_type, K::Less_xy_2 > >
Value_access;
T.insert(points.begin(), points.end());
//coordinate computation in grid
double coor_x, coor_y;
coor_x = window.west;
coor_y = window.north;
for (int rows=0 ; rows<window.rows ; rows++) {
G_percent(rows, window.rows, 2);
if (mask)
Rast_get_c_row(maskfd, mask, rows);
for (int cols=0 ; cols<window.cols ; cols++) {
/* don't interpolate outside of the mask */
if (mask && mask[cols] == 0) {
Rast_set_d_null_value(&dcell[cols], 1);
continue;
K::Point_2 p(coor_x,coor_y);
std::vector< std::pair< Point, Coord_type > > coords;
Coord_type norm = CGAL::natural_neighbor_coordinates_2(T,
p,std::back_inserter(coords)).second;
Coord_type res = CGAL::linear_interpolation(coords.begin(),
coords.end(), norm, Value_access(function_values));
G_debug(5, "x: %f y: %f -> res: %f (row=%d; col=%d)",
coor_x, coor_y, res, rows, cols);
coor_x += ewres;
//std::cout << res << " ";
dcell[cols] = (DCELL) res;
coor_y -= nsres;
//std::cout << std::endl;
Rast_put_d_row(fd, dcell);
G_percent(1, 1, 1);
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
- Re: [cgal-discuss] CGAL::linear_interpolation, Adam Laža, 06/02/2015
