- To:
- Subject: [cgal-discuss] Use of Spherical Kernels in AABB Tree
- Date: Tue, 02 Jun 2015 15:20:05 +0200
Hello,
I am wandering if it is possible to use the AABB Tree algorithm to compute the intersection of a Sphere_3 and a (AABB) tree of Line_arc_3. It seems that the intersection function for a spherical kernel does not have the same number of arguments as that of a cartesian kernel. When I try to refer to AABBTree::Intersection_and_primitive_id<Sphere_3>::Type, I get the following compilation error :
/usr/local/include/CGAL/Circular_kernel_3/function_objects_polynomial_sphere.h:1182:67: error: no type named ‘result_type’ in ‘struct CGAL::Intersection_traits<CGAL::Spherical_kernel_3<CGAL::Simple_cartesian<double>, CGAL::Algebraic_kernel_for_spheres_2_3<double> >, CGAL::Sphere_3<CGAL::Spherical_kernel_3<CGAL::Simple_cartesian<double>, CGAL::Algebraic_kernel_for_spheres_2_3<double> > >, CGAL::Line_arc_3<CGAL::Spherical_kernel_3<CGAL::Simple_cartesian<double>, CGAL::Algebraic_kernel_for_spheres_2_3<double> > > >’
{ typedef typename Intersection_traits<SK, A, B>::result_type type; };
I found a workaround for the intersection function alone on http://stackoverflow.com/questions/26246381/how-to-calculate-the-intersection-of-a-line-segment-and-circle-with-cgal, but I don't see how I can apply that to the AABB tree module.
Thanks for your help,
Best regards,
Clément
- [cgal-discuss] Use of Spherical Kernels in AABB Tree, Clement Roux-Langlois, 06/02/2015
- Re: [cgal-discuss] Use of Spherical Kernels in AABB Tree, Sebastien Loriot (GeometryFactory), 06/02/2015
- Re: [cgal-discuss] Use of Spherical Kernels in AABB Tree, Hexley, 06/03/2015
