cgal-discuss - Re: [cgal-discuss] Taucs installation
  • To:
  • Subject: Re: [cgal-discuss] Taucs installation
  • Date: Tue, 2 Jun 2015 15:59:00 -0700 (PDT)
I have the same problem in ubuntu 12.04 32-bit system. I downloaded taucs
from here https://gforge.inria.fr/frs/?group_id=52, and after make and
install i get this:
~/Documentos/Librerias/taucs_full$ make
mkdir obj
mkdir: cannot create directory `obj': File exists
make: [obj/linux/exists.log] Error 1 (ignored)
mkdir obj/linux/
echo exists > obj/linux/exists.log
cc -c -O3 -Wall -std=c99 -DMACHTYPE_ -I src/ -I build/linux/ -I
external/src/ \
progs/taucs_blas_underscore_test.c \
-o ./obj/linux/taucs_blas_underscore_test.o
cc \
-o ./obj/linux/taucs_blas_underscore_test \
obj/linux/taucs_blas_underscore_test.o -L external/lib/linux
-llapack -L
external/lib/linux -lf77blas -lcblas -latlas -L external/lib/linux -lmetis
-lg2c -lm
obj/linux/taucs_blas_underscore_test build/linux/taucs_config_tests.h
obj/linux/taucs_blas_underscore_test: error while loading shared libraries:
libg2c.so.0: cannot open shared object file: No such file or directory
make: [build/linux/taucs_config_tests.h] Error 127 (ignored)
external/src/ \
progs/taucs_blas_nounderscore_test.c \
-o ./obj/linux/taucs_blas_nounderscore_test.o
cc \
-o ./obj/linux/taucs_blas_nounderscore_test \
obj/linux/taucs_blas_nounderscore_test.o -L external/lib/linux
-llapack
-L external/lib/linux -lf77blas -lcblas -latlas -L external/lib/linux
-lmetis -lg2c -lm
obj/linux/taucs_blas_nounderscore_test.o:taucs_blas_nounderscore_test.c:function
main: error: undefined reference to 'dgemm'
collect2: ld returned 1 exit status
make: [build/linux/taucs_config_tests.h] Error 1 (ignored)
obj/linux/taucs_blas_nounderscore_test build/linux/taucs_config_tests.h
make: obj/linux/taucs_blas_nounderscore_test: Command not found
external/src/ \
progs/taucs_blas_cblaswrap_test.c \
-o ./obj/linux/taucs_blas_cblaswrap_test.o
cc \
-o ./obj/linux/taucs_blas_cblaswrap_test \
obj/linux/taucs_blas_cblaswrap_test.o -L external/lib/linux
-llapack -L
-lg2c -lm
obj/linux/taucs_blas_cblaswrap_test.o:taucs_blas_cblaswrap_test.c:function
main: error: undefined reference to 'f2c_dgemm'
obj/linux/taucs_blas_cblaswrap_test build/linux/taucs_config_tests.h
make: obj/linux/taucs_blas_cblaswrap_test: Command not found
external/src/ \
progs/taucs_c99_complex_test.c \
-o ./obj/linux/taucs_c99_complex_test.o
cc \
-o ./obj/linux/taucs_c99_complex_test \
obj/linux/taucs_c99_complex_test.o -L external/lib/linux -llapack -L
-lg2c -lm
obj/linux/taucs_c99_complex_test build/linux/taucs_config_tests.h
C99 complex numbers seem to be supported, 1+sqrt(-1)=-1.000000+1.000000i
external/src/ \
progs/taucs_cilk_test.c \
-o ./obj/linux/taucs_cilk_test.o
progs/taucs_cilk_test.c:8:19: fatal error: cilk.h: No such file or directory
compilation terminated.
cc \
-o ./obj/linux/taucs_cilk_test \
obj/linux/taucs_cilk_test.o -L external/lib/linux -llapack -L
-lg2c -lm
cc: error: obj/linux/taucs_cilk_test.o: No such file or directory
obj/linux/taucs_cilk_test build/linux/taucs_config_tests.h
make: obj/linux/taucs_cilk_test: Command not found
mkdir bin
mkdir: cannot create directory `bin': File exists
make: [bin/linux/exists.log] Error 1 (ignored)
mkdir bin/linux/
echo exists > bin/linux/exists.log
mkdir lib
mkdir: cannot create directory `lib': File exists
make: [lib/linux/exists.log] Error 1 (ignored)
mkdir lib/linux/
echo exists > lib/linux/exists.log
external/src/ \
-DTAUCS_CORE_GENERAL \
src/taucs_sn_llt.c \
-o ./obj/linux/taucs_sn_llt.o
In file included from src/taucs_sn_llt.c:13:0:
src/taucs.h:83:2: error: #error "taucs_blas_*_test: linking with the BLAS
failed all attempts"
src/taucs.h:837:14: error: ‘taucs_blas_name’ declared as function returning
a function
src/taucs.h:837:1: warning: parameter names (without types) in function
declaration [enabled by default]
src/taucs.h:838:14: error: ‘taucs_blas_name’ declared as function returning
a function
src/taucs.h:838:1: warning: parameter names (without types) in function
src/taucs.h:839:14: error: ‘taucs_blas_name’ declared as function returning
a function
src/taucs.h:839:1: warning: parameter names (without types) in function
src/taucs.h:840:14: error: ‘taucs_blas_name’ declared as function returning
a function
src/taucs.h:840:1: warning: parameter names (without types) in function
src/taucs_sn_llt.c:1339:1: warning: ‘tree_first_descendant’ defined but not
used [-Wunused-function]
make: *** [obj/linux/taucs_sn_llt.o] Error 1
can you help me??
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Taucs-installation-tp952045p4660888.html
