cgal-discuss - Re: [cgal-discuss] Use of Spherical Kernels in AABB Tree
  • To:
  • Subject: Re: [cgal-discuss] Use of Spherical Kernels in AABB Tree
  • Date: Tue, 02 Jun 2015 15:32:30 +0200
On 06/02/2015 03:20 PM, Clement Roux-Langlois wrote:
Hello,
I am wandering if it is possible to use the AABB Tree algorithm to
compute the intersection of a Sphere_3 and a (AABB) tree of Line_arc_3.
It seems that the intersection function for a spherical kernel does not
have the same number of arguments as that of a cartesian kernel. When I
try to refer to AABBTree::Intersection_and_primitive_id<Sphere_3>::Type,
I get the following compilation error :
/usr/local/include/CGAL/Circular_kernel_3/function_objects_polynomial_sphere.h:1182:67:
error: no type named ‘result_type’ in ‘struct
CGAL::Intersection_traits<CGAL::Spherical_kernel_3<CGAL::Simple_cartesian<double>,
CGAL::Algebraic_kernel_for_spheres_2_3<double> >,
CGAL::Sphere_3<CGAL::Spherical_kernel_3<CGAL::Simple_cartesian<double>,
CGAL::Algebraic_kernel_for_spheres_2_3<double> > >,
CGAL::Line_arc_3<CGAL::Spherical_kernel_3<CGAL::Simple_cartesian<double>,
{ typedef typename Intersection_traits<SK, A, B>::result_type
type; };
I found a workaround for the intersection function alone on
http://stackoverflow.com/questions/26246381/how-to-calculate-the-intersection-of-a-line-segment-and-circle-with-cgal,
but I don't see how I can apply that to the AABB tree module.
Thanks for your help,
Best regards,
Clément
The intersection functor does not have the same API as required by the concepts in the AABB-tree:
http://doc.cgal.org/latest/Kernel_23/group__intersection__spherical__grp.html
vs.
http://doc.cgal.org/latest/Kernel_23/group__intersection__linear__grp.html
As documented here:
http://doc.cgal.org/latest/AABB_tree/classAABBTraits.html#a70e323d8c5dd12580bdf06433373b21c
it's the second form that is required.
It should be doable to define a custom traits.
Sebastien
