Re: [cgal-discuss] Intersection segment and cells from 3D Delaunay triangulation
- To:
- Subject: Re: [cgal-discuss] Intersection segment and cells from 3D Delaunay triangulation
- Date: Wed, 03 Jun 2015 11:40:44 +0200
The AABB tree is only worth it if you have many query segments.
A third alternative is to locate an endpoint in the triangulation
and to walk towards the other end point collecting the cells
you traverse.
andreas
On 03/06/2015 11:28, Mauricio Diaz wrote:
Hi,
I wonder how to calculate the intersections between a 3D segment and
some cells from a 3D Delaunay triangulation.
From the documentation, I understand two ways to do it:
- By iterating all over the finite cells of the 3D triangulation and
calculating CGAL::intersection(segment, cell)
- By construction an AABB tree of the cells (the triangle facets) and
finding the intersections with the segment.
Which of these two options is more efficient? Any different suggestion?
Thanks,
- Mauricio DIAZ
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
- [cgal-discuss] Intersection segment and cells from 3D Delaunay triangulation, Mauricio Diaz, 06/03/2015
- Re: [cgal-discuss] Intersection segment and cells from 3D Delaunay triangulation, Andreas Fabri, 06/03/2015
- Re: [cgal-discuss] Intersection segment and cells from 3D Delaunay triangulation, Mauricio Diaz, 06/03/2015
