Re: [cgal-discuss] Intersection segment and cells from 3D Delaunay triangulation
- To:
- Subject: Re: [cgal-discuss] Intersection segment and cells from 3D Delaunay triangulation
- Date: Wed, 03 Jun 2015 13:50:11 +0200
On 03/06/2015 13:12, Mauricio Diaz wrote:
Thanks Andreas,
The AABB tree is only worth it if you have many query segments.Yes, that's my case!
A third alternative is to locate an endpoint in the triangulationThis alternative sounds interesting. What do you mean with "walk towards"?
and to walk towards the other end point collecting the cells
you traverse.
How can this be done?
When you are in a cell, you determine which of the four faces
is interesected by your segment. You jump to the neighbor cell
and so on. Note that you might not intersect a single face
but an edge or a vertex.
andreas
Thanks again,
- Mauricio
----- Mail original -----
De: "Andreas Fabri"
À:
Envoyé: Mercredi 3 Juin 2015 11:40:44
Objet: Re: [cgal-discuss] Intersection segment and cells from 3D Delaunay
triangulation
you traverse.
andreas
On 03/06/2015 11:28, Mauricio Diaz wrote:
Hi,
I wonder how to calculate the intersections between a 3D segment and
some cells from a 3D Delaunay triangulation.
From the documentation, I understand two ways to do it:
- By iterating all over the finite cells of the 3D triangulation and
calculating CGAL::intersection(segment, cell)
- By construction an AABB tree of the cells (the triangle facets) and
finding the intersections with the segment.
Which of these two options is more efficient? Any different suggestion?
Thanks,
- Mauricio DIAZ
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
Andreas Fabri, PhD
- [cgal-discuss] Intersection segment and cells from 3D Delaunay triangulation, Mauricio Diaz, 06/03/2015
- Re: [cgal-discuss] Intersection segment and cells from 3D Delaunay triangulation, Andreas Fabri, 06/03/2015
- Re: [cgal-discuss] Intersection segment and cells from 3D Delaunay triangulation, Mauricio Diaz, 06/03/2015
