- To:
- Subject: Re: [cgal-discuss] Algebraic curves with non-integer coefficients
- Date: Tue, 9 Jun 2015 09:26:31 +0300
The coefficient must be rational.
You have to find a way to make them rational if you want to use this component. ____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
_/
On Mon, Jun 8, 2015 at 4:35 PM, Lee Croft <> wrote:
Hello,
I have a question regarding arrangements with algebraic curves defined by
bi-variate polynomial equations. I have found that it is possible to create
such arrangements using the Arr_algebraic_segment_traits_2 class, however
the class is templated to take a coefficient and according to the
documentation, it can only take one of three types, leda::integer,
CORE::BigInt, or an instance of CGAL::Sqrt_extension instantiated with an
integral type. The application that I am making involves the use of
polynomials which are not guaranteed to have integer coefficients. Is there
any way to allow for rational or real numbers to be used instead or is there
another traits class that I could use instead to achieve this?
Thank you,
Lee
View this message in context: http://cgal-discuss.949826.n4.nabble.com/Algebraic-curves-with-non-integer-coefficients-tp4660902.html
- [cgal-discuss] Algebraic curves with non-integer coefficients, Lee Croft, 06/08/2015
- Re: [cgal-discuss] Algebraic curves with non-integer coefficients, Eric Berberich, 06/08/2015
- Re: [cgal-discuss] Algebraic curves with non-integer coefficients, Lee Croft, 06/08/2015
- Re: [cgal-discuss] Algebraic curves with non-integer coefficients, Efi Fogel, 06/09/2015
- Re: [cgal-discuss] Algebraic curves with non-integer coefficients, Lee Croft, 06/09/2015
