- To:
- Subject: Re: [cgal-discuss] Algebraic curves with non-integer coefficients
- Date: Tue, 9 Jun 2015 10:11:35 -0700 (PDT)
Making them into rational numbers in my application should be fine. Then it
will be simple to convert them to integers by multiplying them by a common
denominator as Eric has suggested.
Thank you.
Efi Fogel wrote
> The coefficient must be rational.
> You have to find a way to make them rational if you want to use this
> component.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Algebraic-curves-with-non-integer-coefficients-tp4660902p4660908.html
- [cgal-discuss] Algebraic curves with non-integer coefficients, Lee Croft, 06/08/2015
- Re: [cgal-discuss] Algebraic curves with non-integer coefficients, Eric Berberich, 06/08/2015
- Re: [cgal-discuss] Algebraic curves with non-integer coefficients, Lee Croft, 06/08/2015
- Re: [cgal-discuss] Algebraic curves with non-integer coefficients, Efi Fogel, 06/09/2015
- Re: [cgal-discuss] Algebraic curves with non-integer coefficients, Lee Croft, 06/09/2015
