Re: [cgal-discuss] Combinatorial map assertion error: is_whole_orbit_unmarked()
- To:
- Subject: Re: [cgal-discuss] Combinatorial map assertion error: is_whole_orbit_unmarked()
- Date: Thu, 11 Jun 2015 22:29:29 -0700 (PDT)
Guillaume Damiand wrote
> Perhaps you call the remove_cell function in a loop on the combinatorial
> map ?
> If this is the case, you need to push in a container (for example a
> std::vector) all the darts of cells to remove, then in a second loop
> iterate through this container and call remove_cell.
I have taken care of that too. I will try to post a minimal code example
demonstrating this problem.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Combinatorial-map-assertion-error-is-whole-orbit-unmarked-tp4660851p4660914.html
- Re: [cgal-discuss] Combinatorial map assertion error: is_whole_orbit_unmarked(), Pranav, 06/11/2015
- Re: [cgal-discuss] Combinatorial map assertion error: is_whole_orbit_unmarked(), Guillaume Damiand, 06/11/2015
- Re: [cgal-discuss] Combinatorial map assertion error: is_whole_orbit_unmarked(), Pranav, 06/12/2015
