- To:
- Subject: [cgal-discuss] install cgal/qglviewer on mac
- Date: Fri, 12 Jun 2015 08:54:52 +0200
Hello,
I installed cgal with brew on the computer of a colleague.
I cannot compile Triangulation 3 demo.
I installed cgal and qglviewer:
brew install cgal --c++11 --imaging --with-eigen3 --with-lapack
brew install libqglviewer
Then I try to compile the T3 demo but it did not find qglviewer (T2 demo works fine)
CMakeCache below
Thanks for your help
# This is the CMakeCache file.
# For build in directory:
/Users/nchenavier/cgal/CGAL-4.6/demo/Triangulation_3/build
# It was generated by CMake: /usr/local/Cellar/cmake/3.2.2/bin/cmake
# You can edit this file to change values found and used by cmake.
# If you do not want to change any of the values, simply exit the editor.
# If you do want to change a value, simply edit, save, and exit the editor.
# The syntax for the file is as follows:
# KEY:TYPE=VALUE
# KEY is the name of a variable in the cache.
# TYPE is a hint to GUIs for the type of VALUE, DO NOT EDIT TYPE!.
# VALUE is the current value for the KEY.
# EXTERNAL cache entries
//Activate parallelism in Triangulation_3
ACTIVATE_CONCURRENT_TRIANGULATION_3:BOOL=OFF
//Activate the debug messages of the script FindBoost
Boost_DEBUG:BOOL=OFF
//Link with static Boost libraries
CGAL_Boost_USE_STATIC_LIBS:BOOL=OFF
//The directory containing a CMake configuration file for CGAL.
CGAL_DIR:PATH=/usr/local/Cellar/cgal/4.6/lib/CGAL
//Set this to TRUE if you want to define or modify any of CMAKE_*_FLAGS.
// When this is FALSE, all the CMAKE_*_FLAGS flags are overriden
// with the values used when building the CGAL libs. For CGAL_*_flags
// (used for ADDITIONAL flags) , there is no need to set this to
// TRUE.
CGAL_DONT_OVERRIDE_CMAKE_FLAGS:BOOL=TRUE
//Path to a program.
CMAKE_AR:FILEPATH=/Library/Developer/CommandLineTools/usr/bin/ar
//Build type: Release or Debug
CMAKE_BUILD_TYPE:STRING=Release
//Enable/Disable color output during build.
CMAKE_COLOR_MAKEFILE:BOOL=ON
//CXX compiler
CMAKE_CXX_COMPILER:FILEPATH=/Library/Developer/CommandLineTools/usr/bin/c++
//C++ compiler flags for both Release and Debug
CMAKE_CXX_FLAGS:STRING=
//Flags used by the compiler during debug builds.
CMAKE_CXX_FLAGS_DEBUG:STRING=-g
//Flags used by the compiler during release builds for minimum
// size.
CMAKE_CXX_FLAGS_MINSIZEREL:STRING=-Os -DNDEBUG
//C++ compiler flags for RELEASE
CMAKE_CXX_FLAGS_RELEASE:STRING=-O3 -DNDEBUG
//Flags used by the compiler during release builds with debug info.
CMAKE_CXX_FLAGS_RELWITHDEBINFO:STRING=-O2 -g -DNDEBUG
//C compiler
CMAKE_C_COMPILER:FILEPATH=/Library/Developer/CommandLineTools/usr/bin/cc
//Flags used by the compiler during all build types.
CMAKE_C_FLAGS:STRING=
CMAKE_C_FLAGS_DEBUG:STRING=-g
// size.
CMAKE_C_FLAGS_MINSIZEREL:STRING=-Os -DNDEBUG
//Flags used by the compiler during release builds.
CMAKE_C_FLAGS_RELEASE:STRING=-O3 -DNDEBUG
CMAKE_C_FLAGS_RELWITHDEBINFO:STRING=-O2 -g -DNDEBUG
//Linker flags for both Release and Debug
CMAKE_EXE_LINKER_FLAGS:STRING=
-Wl,-dylib_file,/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib:/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
//Flags used by the linker during debug builds.
CMAKE_EXE_LINKER_FLAGS_DEBUG:STRING=
//Flags used by the linker during release minsize builds.
CMAKE_EXE_LINKER_FLAGS_MINSIZEREL:STRING=
//Linker flags for RELEASE
CMAKE_EXE_LINKER_FLAGS_RELEASE:STRING=
//Flags used by the linker during Release with Debug Info builds.
CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO:STRING=
//Enable/Disable output of compile commands during generation.
CMAKE_EXPORT_COMPILE_COMMANDS:BOOL=OFF
CMAKE_INSTALL_NAME_TOOL:FILEPATH=/usr/bin/install_name_tool
//Install path prefix, prepended onto install directories.
CMAKE_INSTALL_PREFIX:PATH=/usr/local
CMAKE_LINKER:FILEPATH=/Library/Developer/CommandLineTools/usr/bin/ld
CMAKE_MAKE_PROGRAM:FILEPATH=/usr/bin/make
//User-defined flags
CMAKE_MODULE_LINKER_FLAGS:STRING=
CMAKE_MODULE_LINKER_FLAGS_DEBUG:STRING=
CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL:STRING=
//Flags used by the linker during release builds.
CMAKE_MODULE_LINKER_FLAGS_RELEASE:STRING=
CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO:STRING=
CMAKE_NM:FILEPATH=/Library/Developer/CommandLineTools/usr/bin/nm
CMAKE_OBJCOPY:FILEPATH=CMAKE_OBJCOPY-NOTFOUND
CMAKE_OBJDUMP:FILEPATH=CMAKE_OBJDUMP-NOTFOUND
//Build architectures for OSX
CMAKE_OSX_ARCHITECTURES:STRING=
//Minimum OS X version to target for deployment (at runtime); newer
// APIs weak linked. Set to empty string for default value.
CMAKE_OSX_DEPLOYMENT_TARGET:STRING=
//The product will be built against the headers and libraries located
// inside the indicated SDK.
CMAKE_OSX_SYSROOT:STRING=
//Value Computed by CMake
CMAKE_PROJECT_NAME:STATIC=Triangulation_demo_3
CMAKE_RANLIB:FILEPATH=/Library/Developer/CommandLineTools/usr/bin/ranlib
//Flags used by the linker during the creation of dll's.
CMAKE_SHARED_LINKER_FLAGS:STRING=
CMAKE_SHARED_LINKER_FLAGS_DEBUG:STRING=
CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL:STRING=
CMAKE_SHARED_LINKER_FLAGS_RELEASE:STRING=
CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO:STRING=
//If set, runtime paths are not added when installing shared libraries,
// but are added when building.
CMAKE_SKIP_INSTALL_RPATH:BOOL=NO
//If set, runtime paths are not added when using shared libraries.
CMAKE_SKIP_RPATH:BOOL=NO
//Flags used by the linker during the creation of static libraries.
CMAKE_STATIC_LINKER_FLAGS:STRING=
CMAKE_STATIC_LINKER_FLAGS_DEBUG:STRING=
CMAKE_STATIC_LINKER_FLAGS_MINSIZEREL:STRING=
CMAKE_STATIC_LINKER_FLAGS_RELEASE:STRING=
CMAKE_STATIC_LINKER_FLAGS_RELWITHDEBINFO:STRING=
CMAKE_STRIP:FILEPATH=/Library/Developer/CommandLineTools/usr/bin/strip
//If true, cmake will use relative paths in makefiles and projects.
CMAKE_USE_RELATIVE_PATHS:BOOL=OFF
//If this value is on, makefiles will be generated without the
// .SILENT directive, and all commands will be echoed to the console
// during the make. This is useful for debugging only. With Visual
// Studio IDE projects all commands are done without /nologo.
CMAKE_VERBOSE_MAKEFILE:BOOL=FALSE
//Link with TBB anyway so we can use TBB timers for profiling
LINK_WITH_TBB:BOOL=ON
//Include for OpenGL on OSX
OPENGL_INCLUDE_DIR:PATH=/System/Library/Frameworks/OpenGL.framework
//OpenGL lib for OSX
OPENGL_gl_LIBRARY:FILEPATH=/System/Library/Frameworks/OpenGL.framework
//AGL lib for OSX
OPENGL_glu_LIBRARY:FILEPATH=/System/Library/Frameworks/AGL.framework
//Path to a file.
QGLVIEWER_INCLUDE_DIR:PATH=QGLVIEWER_INCLUDE_DIR-NOTFOUND
//The QGLViewer library
QGLVIEWER_LIBRARIES:FILEPATH=/usr/local/lib/qglviewer.framework
//Path to a library.
QGLVIEWER_LIBRARY_DEBUG:FILEPATH=QGLVIEWER_LIBRARY_DEBUG-NOTFOUND
QGLVIEWER_LIBRARY_RELEASE:FILEPATH=/usr/local/lib/qglviewer.framework
QT_ARTHURPLUGIN_PLUGIN_DEBUG:FILEPATH=QT_ARTHURPLUGIN_PLUGIN_DEBUG-NOTFOUND
QT_ARTHURPLUGIN_PLUGIN_RELEASE:FILEPATH=QT_ARTHURPLUGIN_PLUGIN_RELEASE-NOTFOUND
QT_CONTAINEREXTENSION_PLUGIN_DEBUG:FILEPATH=QT_CONTAINEREXTENSION_PLUGIN_DEBUG-NOTFOUND
QT_CONTAINEREXTENSION_PLUGIN_RELEASE:FILEPATH=QT_CONTAINEREXTENSION_PLUGIN_RELEASE-NOTFOUND
QT_CUSTOMWIDGETPLUGIN_PLUGIN_DEBUG:FILEPATH=QT_CUSTOMWIDGETPLUGIN_PLUGIN_DEBUG-NOTFOUND
QT_CUSTOMWIDGETPLUGIN_PLUGIN_RELEASE:FILEPATH=QT_CUSTOMWIDGETPLUGIN_PLUGIN_RELEASE-NOTFOUND
QT_DBUSCPP2XML_EXECUTABLE:FILEPATH=QT_DBUSCPP2XML_EXECUTABLE-NOTFOUND
QT_DBUSXML2CPP_EXECUTABLE:FILEPATH=QT_DBUSXML2CPP_EXECUTABLE-NOTFOUND
QT_DESIGNER_EXECUTABLE:FILEPATH=QT_DESIGNER_EXECUTABLE-NOTFOUND
//The location of the Qt docs
QT_DOC_DIR:PATH=/usr/local/Cellar/qt/4.8.6/doc
//The location of the Qt imports
QT_IMPORTS_DIR:PATH=/usr/local/Cellar/qt/4.8.6/imports
QT_LINGUIST_EXECUTABLE:FILEPATH=QT_LINGUIST_EXECUTABLE-NOTFOUND
QT_LRELEASE_EXECUTABLE:FILEPATH=/usr/local/Cellar/qt/4.8.6/bin/lrelease
QT_LUPDATE_EXECUTABLE:FILEPATH=/usr/local/Cellar/qt/4.8.6/bin/lupdate
//The location of the Qt mkspecs containing qconfig.pri
QT_MKSPECS_DIR:PATH=/usr/local/Cellar/qt/4.8.6/mkspecs
QT_MOC_EXECUTABLE:FILEPATH=/usr/local/Cellar/qt/4.8.6/bin/moc
QT_PHONONWIDGETS_PLUGIN_DEBUG:FILEPATH=QT_PHONONWIDGETS_PLUGIN_DEBUG-NOTFOUND
QT_PHONONWIDGETS_PLUGIN_RELEASE:FILEPATH=/usr/local/Cellar/qt/4.8.6/plugins/designer/libphononwidgets.dylib
//Path to a file.
QT_PHONON_INCLUDE_DIR:PATH=/usr/local/Cellar/qt/4.8.6/include/phonon
//The Qt PHONON library
QT_PHONON_LIBRARY:STRING=optimized;/usr/local/Cellar/qt/4.8.6/lib/phonon.framework;debug;/usr/local/Cellar/qt/4.8.6/lib/phonon.framework
QT_PHONON_LIBRARY_DEBUG:FILEPATH=QT_PHONON_LIBRARY_DEBUG-NOTFOUND
QT_PHONON_LIBRARY_RELEASE:FILEPATH=/usr/local/Cellar/qt/4.8.6/lib/phonon.framework
QT_PHONON_QT7_PLUGIN_DEBUG:FILEPATH=QT_PHONON_QT7_PLUGIN_DEBUG-NOTFOUND
QT_PHONON_QT7_PLUGIN_RELEASE:FILEPATH=/usr/local/Cellar/qt/4.8.6/plugins/phonon_backend/libphonon_qt7.dylib
//The location of the Qt plugins
QT_PLUGINS_DIR:PATH=/usr/local/Cellar/qt/4.8.6/plugins
QT_QCNCODECS_PLUGIN_DEBUG:FILEPATH=QT_QCNCODECS_PLUGIN_DEBUG-NOTFOUND
QT_QCNCODECS_PLUGIN_RELEASE:FILEPATH=/usr/local/Cellar/qt/4.8.6/plugins/codecs/libqcncodecs.dylib
QT_QCOLLECTIONGENERATOR_EXECUTABLE:FILEPATH=/usr/local/Cellar/qt/4.8.6/bin/qcollectiongenerator
QT_QCOREWLANBEARER_PLUGIN_DEBUG:FILEPATH=QT_QCOREWLANBEARER_PLUGIN_DEBUG-NOTFOUND
QT_QCOREWLANBEARER_PLUGIN_RELEASE:FILEPATH=/usr/local/Cellar/qt/4.8.6/plugins/bearer/libqcorewlanbearer.dylib
QT_QDECLARATIVEVIEW_PLUGIN_DEBUG:FILEPATH=QT_QDECLARATIVEVIEW_PLUGIN_DEBUG-NOTFOUND
QT_QDECLARATIVEVIEW_PLUGIN_RELEASE:FILEPATH=/usr/local/Cellar/qt/4.8.6/plugins/designer/libqdeclarativeview.dylib
QT_QDECORATIONDEFAULT_PLUGIN_DEBUG:FILEPATH=QT_QDECORATIONDEFAULT_PLUGIN_DEBUG-NOTFOUND
QT_QDECORATIONDEFAULT_PLUGIN_RELEASE:FILEPATH=QT_QDECORATIONDEFAULT_PLUGIN_RELEASE-NOTFOUND
QT_QDECORATIONWINDOWS_PLUGIN_DEBUG:FILEPATH=QT_QDECORATIONWINDOWS_PLUGIN_DEBUG-NOTFOUND
QT_QDECORATIONWINDOWS_PLUGIN_RELEASE:FILEPATH=QT_QDECORATIONWINDOWS_PLUGIN_RELEASE-NOTFOUND
QT_QGENERICBEARER_PLUGIN_DEBUG:FILEPATH=QT_QGENERICBEARER_PLUGIN_DEBUG-NOTFOUND
QT_QGENERICBEARER_PLUGIN_RELEASE:FILEPATH=/usr/local/Cellar/qt/4.8.6/plugins/bearer/libqgenericbearer.dylib
QT_QGIF_PLUGIN_DEBUG:FILEPATH=QT_QGIF_PLUGIN_DEBUG-NOTFOUND
QT_QGIF_PLUGIN_RELEASE:FILEPATH=/usr/local/Cellar/qt/4.8.6/plugins/imageformats/libqgif.dylib
QT_QGLGRAPHICSSYSTEM_PLUGIN_DEBUG:FILEPATH=QT_QGLGRAPHICSSYSTEM_PLUGIN_DEBUG-NOTFOUND
QT_QGLGRAPHICSSYSTEM_PLUGIN_RELEASE:FILEPATH=/usr/local/Cellar/qt/4.8.6/plugins/graphicssystems/libqglgraphicssystem.dylib
QT_QICO_PLUGIN_DEBUG:FILEPATH=QT_QICO_PLUGIN_DEBUG-NOTFOUND
QT_QICO_PLUGIN_RELEASE:FILEPATH=/usr/local/Cellar/qt/4.8.6/plugins/imageformats/libqico.dylib
QT_QIMSW_MULTI_PLUGIN_DEBUG:FILEPATH=QT_QIMSW_MULTI_PLUGIN_DEBUG-NOTFOUND
QT_QIMSW_MULTI_PLUGIN_RELEASE:FILEPATH=QT_QIMSW_MULTI_PLUGIN_RELEASE-NOTFOUND
QT_QJPCODECS_PLUGIN_DEBUG:FILEPATH=QT_QJPCODECS_PLUGIN_DEBUG-NOTFOUND
QT_QJPCODECS_PLUGIN_RELEASE:FILEPATH=/usr/local/Cellar/qt/4.8.6/plugins/codecs/libqjpcodecs.dylib
QT_QJPEG_PLUGIN_DEBUG:FILEPATH=QT_QJPEG_PLUGIN_DEBUG-NOTFOUND
QT_QJPEG_PLUGIN_RELEASE:FILEPATH=/usr/local/Cellar/qt/4.8.6/plugins/imageformats/libqjpeg.dylib
QT_QKRCODECS_PLUGIN_DEBUG:FILEPATH=QT_QKRCODECS_PLUGIN_DEBUG-NOTFOUND
QT_QKRCODECS_PLUGIN_RELEASE:FILEPATH=/usr/local/Cellar/qt/4.8.6/plugins/codecs/libqkrcodecs.dylib
//The qmake executable for the Qt installation to use
QT_QMAKE_EXECUTABLE:FILEPATH=/usr/local/bin/qmake
QT_QMNG_PLUGIN_DEBUG:FILEPATH=QT_QMNG_PLUGIN_DEBUG-NOTFOUND
QT_QMNG_PLUGIN_RELEASE:FILEPATH=/usr/local/Cellar/qt/4.8.6/plugins/imageformats/libqmng.dylib
QT_QNATIVEWIFIBEARER_PLUGIN_DEBUG:FILEPATH=QT_QNATIVEWIFIBEARER_PLUGIN_DEBUG-NOTFOUND
QT_QNATIVEWIFIBEARER_PLUGIN_RELEASE:FILEPATH=QT_QNATIVEWIFIBEARER_PLUGIN_RELEASE-NOTFOUND
QT_QSQLDB2_PLUGIN_DEBUG:FILEPATH=QT_QSQLDB2_PLUGIN_DEBUG-NOTFOUND
QT_QSQLDB2_PLUGIN_RELEASE:FILEPATH=QT_QSQLDB2_PLUGIN_RELEASE-NOTFOUND
QT_QSQLIBASE_PLUGIN_DEBUG:FILEPATH=QT_QSQLIBASE_PLUGIN_DEBUG-NOTFOUND
QT_QSQLIBASE_PLUGIN_RELEASE:FILEPATH=QT_QSQLIBASE_PLUGIN_RELEASE-NOTFOUND
QT_QSQLITE2_PLUGIN_DEBUG:FILEPATH=QT_QSQLITE2_PLUGIN_DEBUG-NOTFOUND
QT_QSQLITE2_PLUGIN_RELEASE:FILEPATH=QT_QSQLITE2_PLUGIN_RELEASE-NOTFOUND
QT_QSQLITE_PLUGIN_DEBUG:FILEPATH=QT_QSQLITE_PLUGIN_DEBUG-NOTFOUND
QT_QSQLITE_PLUGIN_RELEASE:FILEPATH=/usr/local/Cellar/qt/4.8.6/plugins/sqldrivers/libqsqlite.dylib
QT_QSQLMYSQL_PLUGIN_DEBUG:FILEPATH=QT_QSQLMYSQL_PLUGIN_DEBUG-NOTFOUND
QT_QSQLMYSQL_PLUGIN_RELEASE:FILEPATH=QT_QSQLMYSQL_PLUGIN_RELEASE-NOTFOUND
QT_QSQLOCI_PLUGIN_DEBUG:FILEPATH=QT_QSQLOCI_PLUGIN_DEBUG-NOTFOUND
QT_QSQLOCI_PLUGIN_RELEASE:FILEPATH=QT_QSQLOCI_PLUGIN_RELEASE-NOTFOUND
QT_QSQLODBC_PLUGIN_DEBUG:FILEPATH=QT_QSQLODBC_PLUGIN_DEBUG-NOTFOUND
QT_QSQLODBC_PLUGIN_RELEASE:FILEPATH=QT_QSQLODBC_PLUGIN_RELEASE-NOTFOUND
QT_QSQLPSQL_PLUGIN_DEBUG:FILEPATH=QT_QSQLPSQL_PLUGIN_DEBUG-NOTFOUND
QT_QSQLPSQL_PLUGIN_RELEASE:FILEPATH=QT_QSQLPSQL_PLUGIN_RELEASE-NOTFOUND
QT_QSQLTDS_PLUGIN_DEBUG:FILEPATH=QT_QSQLTDS_PLUGIN_DEBUG-NOTFOUND
QT_QSQLTDS_PLUGIN_RELEASE:FILEPATH=QT_QSQLTDS_PLUGIN_RELEASE-NOTFOUND
QT_QSVGICON_PLUGIN_DEBUG:FILEPATH=QT_QSVGICON_PLUGIN_DEBUG-NOTFOUND
QT_QSVGICON_PLUGIN_RELEASE:FILEPATH=/usr/local/Cellar/qt/4.8.6/plugins/iconengines/libqsvgicon.dylib
QT_QSVG_PLUGIN_DEBUG:FILEPATH=QT_QSVG_PLUGIN_DEBUG-NOTFOUND
QT_QSVG_PLUGIN_RELEASE:FILEPATH=/usr/local/Cellar/qt/4.8.6/plugins/imageformats/libqsvg.dylib
QT_QT3SUPPORTWIDGETS_PLUGIN_DEBUG:FILEPATH=QT_QT3SUPPORTWIDGETS_PLUGIN_DEBUG-NOTFOUND
QT_QT3SUPPORTWIDGETS_PLUGIN_RELEASE:FILEPATH=QT_QT3SUPPORTWIDGETS_PLUGIN_RELEASE-NOTFOUND
//Path to a file.
QT_QT3SUPPORT_INCLUDE_DIR:PATH=QT_QT3SUPPORT_INCLUDE_DIR-NOTFOUND
//The Qt QT3SUPPORT library
QT_QT3SUPPORT_LIBRARY:STRING=
QT_QT3SUPPORT_LIBRARY_DEBUG:FILEPATH=QT_QT3SUPPORT_LIBRARY_DEBUG-NOTFOUND
QT_QT3SUPPORT_LIBRARY_RELEASE:FILEPATH=QT_QT3SUPPORT_LIBRARY_RELEASE-NOTFOUND
QT_QTACCESSIBLECOMPATWIDGETS_PLUGIN_DEBUG:FILEPATH=QT_QTACCESSIBLECOMPATWIDGETS_PLUGIN_DEBUG-NOTFOUND
QT_QTACCESSIBLECOMPATWIDGETS_PLUGIN_RELEASE:FILEPATH=QT_QTACCESSIBLECOMPATWIDGETS_PLUGIN_RELEASE-NOTFOUND
QT_QTACCESSIBLEWIDGETS_PLUGIN_DEBUG:FILEPATH=QT_QTACCESSIBLEWIDGETS_PLUGIN_DEBUG-NOTFOUND
QT_QTACCESSIBLEWIDGETS_PLUGIN_RELEASE:FILEPATH=/usr/local/Cellar/qt/4.8.6/plugins/accessible/libqtaccessiblewidgets.dylib
//Path to a file.
QT_QTASSISTANTCLIENT_INCLUDE_DIR:PATH=QT_QTASSISTANTCLIENT_INCLUDE_DIR-NOTFOUND
//The Qt QTASSISTANTCLIENT library
QT_QTASSISTANTCLIENT_LIBRARY:STRING=
QT_QTASSISTANTCLIENT_LIBRARY_DEBUG:FILEPATH=QT_QTASSISTANTCLIENT_LIBRARY_DEBUG-NOTFOUND
QT_QTASSISTANTCLIENT_LIBRARY_RELEASE:FILEPATH=QT_QTASSISTANTCLIENT_LIBRARY_RELEASE-NOTFOUND
//Path to a file.
QT_QTASSISTANT_INCLUDE_DIR:PATH=QT_QTASSISTANT_INCLUDE_DIR-NOTFOUND
//The Qt QTASSISTANT library
QT_QTASSISTANT_LIBRARY:STRING=
QT_QTASSISTANT_LIBRARY_DEBUG:FILEPATH=QT_QTASSISTANT_LIBRARY_DEBUG-NOTFOUND
QT_QTASSISTANT_LIBRARY_RELEASE:FILEPATH=QT_QTASSISTANT_LIBRARY_RELEASE-NOTFOUND
//The Qt QTCLUCENE library
QT_QTCLUCENE_LIBRARY:STRING=optimized;/usr/local/Cellar/qt/4.8.6/lib/libQtCLucene.dylib;debug;/usr/local/Cellar/qt/4.8.6/lib/libQtCLucene.dylib
QT_QTCLUCENE_LIBRARY_DEBUG:FILEPATH=QT_QTCLUCENE_LIBRARY_DEBUG-NOTFOUND
QT_QTCLUCENE_LIBRARY_RELEASE:FILEPATH=/usr/local/Cellar/qt/4.8.6/lib/libQtCLucene.dylib
//Path to a file.
QT_QTCORE_INCLUDE_DIR:PATH=/usr/local/Cellar/qt/4.8.6/lib/QtCore.framework/Headers
//The Qt QTCORE library
QT_QTCORE_LIBRARY:STRING=optimized;/usr/local/Cellar/qt/4.8.6/lib/QtCore.framework;debug;/usr/local/Cellar/qt/4.8.6/lib/QtCore.framework
QT_QTCORE_LIBRARY_DEBUG:FILEPATH=QT_QTCORE_LIBRARY_DEBUG-NOTFOUND
QT_QTCORE_LIBRARY_RELEASE:FILEPATH=/usr/local/Cellar/qt/4.8.6/lib/QtCore.framework
//Path to a file.
QT_QTDBUS_INCLUDE_DIR:PATH=QT_QTDBUS_INCLUDE_DIR-NOTFOUND
//The Qt QTDBUS library
QT_QTDBUS_LIBRARY:STRING=
QT_QTDBUS_LIBRARY_DEBUG:FILEPATH=QT_QTDBUS_LIBRARY_DEBUG-NOTFOUND
QT_QTDBUS_LIBRARY_RELEASE:FILEPATH=QT_QTDBUS_LIBRARY_RELEASE-NOTFOUND
//Path to a file.
QT_QTDECLARATIVE_INCLUDE_DIR:PATH=/usr/local/Cellar/qt/4.8.6/include/QtDeclarative
//The Qt QTDECLARATIVE library
QT_QTDECLARATIVE_LIBRARY:STRING=optimized;/usr/local/Cellar/qt/4.8.6/lib/QtDeclarative.framework;debug;/usr/local/Cellar/qt/4.8.6/lib/QtDeclarative.framework
QT_QTDECLARATIVE_LIBRARY_DEBUG:FILEPATH=QT_QTDECLARATIVE_LIBRARY_DEBUG-NOTFOUND
QT_QTDECLARATIVE_LIBRARY_RELEASE:FILEPATH=/usr/local/Cellar/qt/4.8.6/lib/QtDeclarative.framework
//Path to a file.
QT_QTDESIGNERCOMPONENTS_INCLUDE_DIR:PATH=/usr/local/Cellar/qt/4.8.6/include/QtDesigner
//The Qt QTDESIGNERCOMPONENTS library
QT_QTDESIGNERCOMPONENTS_LIBRARY:STRING=optimized;/usr/local/Cellar/qt/4.8.6/lib/QtDesignerComponents.framework;debug;/usr/local/Cellar/qt/4.8.6/lib/QtDesignerComponents.framework
QT_QTDESIGNERCOMPONENTS_LIBRARY_DEBUG:FILEPATH=QT_QTDESIGNERCOMPONENTS_LIBRARY_DEBUG-NOTFOUND
QT_QTDESIGNERCOMPONENTS_LIBRARY_RELEASE:FILEPATH=/usr/local/Cellar/qt/4.8.6/lib/QtDesignerComponents.framework
//Path to a file.
QT_QTDESIGNER_INCLUDE_DIR:PATH=/usr/local/Cellar/qt/4.8.6/include/QtDesigner
//The Qt QTDESIGNER library
QT_QTDESIGNER_LIBRARY:STRING=optimized;/usr/local/Cellar/qt/4.8.6/lib/QtDesigner.framework;debug;/usr/local/Cellar/qt/4.8.6/lib/QtDesigner.framework
QT_QTDESIGNER_LIBRARY_DEBUG:FILEPATH=QT_QTDESIGNER_LIBRARY_DEBUG-NOTFOUND
QT_QTDESIGNER_LIBRARY_RELEASE:FILEPATH=/usr/local/Cellar/qt/4.8.6/lib/QtDesigner.framework
QT_QTGA_PLUGIN_DEBUG:FILEPATH=QT_QTGA_PLUGIN_DEBUG-NOTFOUND
QT_QTGA_PLUGIN_RELEASE:FILEPATH=/usr/local/Cellar/qt/4.8.6/plugins/imageformats/libqtga.dylib
//Path to a file.
QT_QTGUI_INCLUDE_DIR:PATH=/usr/local/Cellar/qt/4.8.6/include/QtGui
//The Qt QTGUI library
QT_QTGUI_LIBRARY:STRING=optimized;/usr/local/Cellar/qt/4.8.6/lib/QtGui.framework;debug;/usr/local/Cellar/qt/4.8.6/lib/QtGui.framework
QT_QTGUI_LIBRARY_DEBUG:FILEPATH=QT_QTGUI_LIBRARY_DEBUG-NOTFOUND
QT_QTGUI_LIBRARY_RELEASE:FILEPATH=/usr/local/Cellar/qt/4.8.6/lib/QtGui.framework
//Path to a file.
QT_QTHELP_INCLUDE_DIR:PATH=/usr/local/Cellar/qt/4.8.6/include/QtHelp
//The Qt QTHELP library
QT_QTHELP_LIBRARY:STRING=optimized;/usr/local/Cellar/qt/4.8.6/lib/QtHelp.framework;debug;/usr/local/Cellar/qt/4.8.6/lib/QtHelp.framework
QT_QTHELP_LIBRARY_DEBUG:FILEPATH=QT_QTHELP_LIBRARY_DEBUG-NOTFOUND
QT_QTHELP_LIBRARY_RELEASE:FILEPATH=/usr/local/Cellar/qt/4.8.6/lib/QtHelp.framework
QT_QTIFF_PLUGIN_DEBUG:FILEPATH=QT_QTIFF_PLUGIN_DEBUG-NOTFOUND
QT_QTIFF_PLUGIN_RELEASE:FILEPATH=/usr/local/Cellar/qt/4.8.6/plugins/imageformats/libqtiff.dylib
//Path to a file.
QT_QTMULTIMEDIA_INCLUDE_DIR:PATH=/usr/local/Cellar/qt/4.8.6/include/QtMultimedia
//The Qt QTMULTIMEDIA library
QT_QTMULTIMEDIA_LIBRARY:STRING=optimized;/usr/local/Cellar/qt/4.8.6/lib/QtMultimedia.framework;debug;/usr/local/Cellar/qt/4.8.6/lib/QtMultimedia.framework
QT_QTMULTIMEDIA_LIBRARY_DEBUG:FILEPATH=QT_QTMULTIMEDIA_LIBRARY_DEBUG-NOTFOUND
QT_QTMULTIMEDIA_LIBRARY_RELEASE:FILEPATH=/usr/local/Cellar/qt/4.8.6/lib/QtMultimedia.framework
//Path to a file.
QT_QTNETWORK_INCLUDE_DIR:PATH=/usr/local/Cellar/qt/4.8.6/include/QtNetwork
//The Qt QTNETWORK library
QT_QTNETWORK_LIBRARY:STRING=optimized;/usr/local/Cellar/qt/4.8.6/lib/QtNetwork.framework;debug;/usr/local/Cellar/qt/4.8.6/lib/QtNetwork.framework
QT_QTNETWORK_LIBRARY_DEBUG:FILEPATH=QT_QTNETWORK_LIBRARY_DEBUG-NOTFOUND
QT_QTNETWORK_LIBRARY_RELEASE:FILEPATH=/usr/local/Cellar/qt/4.8.6/lib/QtNetwork.framework
//Path to a file.
QT_QTNSPLUGIN_INCLUDE_DIR:PATH=QT_QTNSPLUGIN_INCLUDE_DIR-NOTFOUND
//The Qt QTNSPLUGIN library
QT_QTNSPLUGIN_LIBRARY:STRING=
QT_QTNSPLUGIN_LIBRARY_DEBUG:FILEPATH=QT_QTNSPLUGIN_LIBRARY_DEBUG-NOTFOUND
QT_QTNSPLUGIN_LIBRARY_RELEASE:FILEPATH=QT_QTNSPLUGIN_LIBRARY_RELEASE-NOTFOUND
//Path to a file.
QT_QTOPENGL_INCLUDE_DIR:PATH=/usr/local/Cellar/qt/4.8.6/include/QtOpenGL
//The Qt QTOPENGL library
QT_QTOPENGL_LIBRARY:STRING=optimized;/usr/local/Cellar/qt/4.8.6/lib/QtOpenGL.framework;debug;/usr/local/Cellar/qt/4.8.6/lib/QtOpenGL.framework
QT_QTOPENGL_LIBRARY_DEBUG:FILEPATH=QT_QTOPENGL_LIBRARY_DEBUG-NOTFOUND
QT_QTOPENGL_LIBRARY_RELEASE:FILEPATH=/usr/local/Cellar/qt/4.8.6/lib/QtOpenGL.framework
QT_QTRACEGRAPHICSSYSTEM_PLUGIN_DEBUG:FILEPATH=QT_QTRACEGRAPHICSSYSTEM_PLUGIN_DEBUG-NOTFOUND
QT_QTRACEGRAPHICSSYSTEM_PLUGIN_RELEASE:FILEPATH=/usr/local/Cellar/qt/4.8.6/plugins/graphicssystems/libqtracegraphicssystem.dylib
QT_QTSCRIPTDBUS_PLUGIN_DEBUG:FILEPATH=QT_QTSCRIPTDBUS_PLUGIN_DEBUG-NOTFOUND
QT_QTSCRIPTDBUS_PLUGIN_RELEASE:FILEPATH=QT_QTSCRIPTDBUS_PLUGIN_RELEASE-NOTFOUND
//Path to a file.
QT_QTSCRIPTTOOLS_INCLUDE_DIR:PATH=/usr/local/Cellar/qt/4.8.6/include/QtScriptTools
//The Qt QTSCRIPTTOOLS library
QT_QTSCRIPTTOOLS_LIBRARY:STRING=optimized;/usr/local/Cellar/qt/4.8.6/lib/QtScriptTools.framework;debug;/usr/local/Cellar/qt/4.8.6/lib/QtScriptTools.framework
QT_QTSCRIPTTOOLS_LIBRARY_DEBUG:FILEPATH=QT_QTSCRIPTTOOLS_LIBRARY_DEBUG-NOTFOUND
QT_QTSCRIPTTOOLS_LIBRARY_RELEASE:FILEPATH=/usr/local/Cellar/qt/4.8.6/lib/QtScriptTools.framework
//Path to a file.
QT_QTSCRIPT_INCLUDE_DIR:PATH=/usr/local/Cellar/qt/4.8.6/include/QtScript
//The Qt QTSCRIPT library
QT_QTSCRIPT_LIBRARY:STRING=optimized;/usr/local/Cellar/qt/4.8.6/lib/QtScript.framework;debug;/usr/local/Cellar/qt/4.8.6/lib/QtScript.framework
QT_QTSCRIPT_LIBRARY_DEBUG:FILEPATH=QT_QTSCRIPT_LIBRARY_DEBUG-NOTFOUND
QT_QTSCRIPT_LIBRARY_RELEASE:FILEPATH=/usr/local/Cellar/qt/4.8.6/lib/QtScript.framework
//Path to a file.
QT_QTSQL_INCLUDE_DIR:PATH=/usr/local/Cellar/qt/4.8.6/include/QtSql
//The Qt QTSQL library
QT_QTSQL_LIBRARY:STRING=optimized;/usr/local/Cellar/qt/4.8.6/lib/QtSql.framework;debug;/usr/local/Cellar/qt/4.8.6/lib/QtSql.framework
QT_QTSQL_LIBRARY_DEBUG:FILEPATH=QT_QTSQL_LIBRARY_DEBUG-NOTFOUND
QT_QTSQL_LIBRARY_RELEASE:FILEPATH=/usr/local/Cellar/qt/4.8.6/lib/QtSql.framework
//Path to a file.
QT_QTSVG_INCLUDE_DIR:PATH=/usr/local/Cellar/qt/4.8.6/include/QtSvg
//The Qt QTSVG library
QT_QTSVG_LIBRARY:STRING=optimized;/usr/local/Cellar/qt/4.8.6/lib/QtSvg.framework;debug;/usr/local/Cellar/qt/4.8.6/lib/QtSvg.framework
QT_QTSVG_LIBRARY_DEBUG:FILEPATH=QT_QTSVG_LIBRARY_DEBUG-NOTFOUND
QT_QTSVG_LIBRARY_RELEASE:FILEPATH=/usr/local/Cellar/qt/4.8.6/lib/QtSvg.framework
//Path to a file.
QT_QTTEST_INCLUDE_DIR:PATH=/usr/local/Cellar/qt/4.8.6/include/QtTest
//The Qt QTTEST library
QT_QTTEST_LIBRARY:STRING=optimized;/usr/local/Cellar/qt/4.8.6/lib/QtTest.framework;debug;/usr/local/Cellar/qt/4.8.6/lib/QtTest.framework
QT_QTTEST_LIBRARY_DEBUG:FILEPATH=QT_QTTEST_LIBRARY_DEBUG-NOTFOUND
QT_QTTEST_LIBRARY_RELEASE:FILEPATH=/usr/local/Cellar/qt/4.8.6/lib/QtTest.framework
//Path to a file.
QT_QTUITOOLS_INCLUDE_DIR:PATH=/usr/local/Cellar/qt/4.8.6/include/QtUiTools
//The Qt QTUITOOLS library
QT_QTUITOOLS_LIBRARY:STRING=optimized;/usr/local/Cellar/qt/4.8.6/lib/libQtUiTools.a;debug;/usr/local/Cellar/qt/4.8.6/lib/libQtUiTools_debug.a
QT_QTUITOOLS_LIBRARY_DEBUG:FILEPATH=/usr/local/Cellar/qt/4.8.6/lib/libQtUiTools_debug.a
QT_QTUITOOLS_LIBRARY_RELEASE:FILEPATH=/usr/local/Cellar/qt/4.8.6/lib/libQtUiTools.a
QT_QTWCODECS_PLUGIN_DEBUG:FILEPATH=QT_QTWCODECS_PLUGIN_DEBUG-NOTFOUND
QT_QTWCODECS_PLUGIN_RELEASE:FILEPATH=/usr/local/Cellar/qt/4.8.6/plugins/codecs/libqtwcodecs.dylib
//Path to a file.
QT_QTWEBKIT_INCLUDE_DIR:PATH=/usr/local/Cellar/qt/4.8.6/include/QtWebKit
//The Qt QTWEBKIT library
QT_QTWEBKIT_LIBRARY:STRING=optimized;/usr/local/Cellar/qt/4.8.6/lib/QtWebKit.framework;debug;/usr/local/Cellar/qt/4.8.6/lib/QtWebKit.framework
QT_QTWEBKIT_LIBRARY_DEBUG:FILEPATH=QT_QTWEBKIT_LIBRARY_DEBUG-NOTFOUND
QT_QTWEBKIT_LIBRARY_RELEASE:FILEPATH=/usr/local/Cellar/qt/4.8.6/lib/QtWebKit.framework
//Path to a file.
QT_QTXMLPATTERNS_INCLUDE_DIR:PATH=/usr/local/Cellar/qt/4.8.6/include/QtXmlPatterns
//The Qt QTXMLPATTERNS library
QT_QTXMLPATTERNS_LIBRARY:STRING=optimized;/usr/local/Cellar/qt/4.8.6/lib/QtXmlPatterns.framework;debug;/usr/local/Cellar/qt/4.8.6/lib/QtXmlPatterns.framework
QT_QTXMLPATTERNS_LIBRARY_DEBUG:FILEPATH=QT_QTXMLPATTERNS_LIBRARY_DEBUG-NOTFOUND
QT_QTXMLPATTERNS_LIBRARY_RELEASE:FILEPATH=/usr/local/Cellar/qt/4.8.6/lib/QtXmlPatterns.framework
//Path to a file.
QT_QTXML_INCLUDE_DIR:PATH=/usr/local/Cellar/qt/4.8.6/include/QtXml
//The Qt QTXML library
QT_QTXML_LIBRARY:STRING=optimized;/usr/local/Cellar/qt/4.8.6/lib/QtXml.framework;debug;/usr/local/Cellar/qt/4.8.6/lib/QtXml.framework
QT_QTXML_LIBRARY_DEBUG:FILEPATH=QT_QTXML_LIBRARY_DEBUG-NOTFOUND
QT_QTXML_LIBRARY_RELEASE:FILEPATH=/usr/local/Cellar/qt/4.8.6/lib/QtXml.framework
QT_QWEBVIEW_PLUGIN_DEBUG:FILEPATH=QT_QWEBVIEW_PLUGIN_DEBUG-NOTFOUND
QT_QWEBVIEW_PLUGIN_RELEASE:FILEPATH=/usr/local/Cellar/qt/4.8.6/plugins/designer/libqwebview.dylib
QT_QWSTSLIBMOUSEHANDLER_PLUGIN_DEBUG:FILEPATH=QT_QWSTSLIBMOUSEHANDLER_PLUGIN_DEBUG-NOTFOUND
QT_QWSTSLIBMOUSEHANDLER_PLUGIN_RELEASE:FILEPATH=QT_QWSTSLIBMOUSEHANDLER_PLUGIN_RELEASE-NOTFOUND
QT_RCC_EXECUTABLE:FILEPATH=/usr/local/Cellar/qt/4.8.6/bin/rcc
QT_TASKMENUEXTENSION_PLUGIN_DEBUG:FILEPATH=QT_TASKMENUEXTENSION_PLUGIN_DEBUG-NOTFOUND
QT_TASKMENUEXTENSION_PLUGIN_RELEASE:FILEPATH=QT_TASKMENUEXTENSION_PLUGIN_RELEASE-NOTFOUND
//The location of the Qt translations
QT_TRANSLATIONS_DIR:PATH=/usr/local/Cellar/qt/4.8.6/translations
QT_UIC3_EXECUTABLE:FILEPATH=QT_UIC3_EXECUTABLE-NOTFOUND
QT_UIC_EXECUTABLE:FILEPATH=/usr/local/Cellar/qt/4.8.6/bin/uic
QT_WORLDTIMECLOCKPLUGIN_PLUGIN_DEBUG:FILEPATH=QT_WORLDTIMECLOCKPLUGIN_PLUGIN_DEBUG-NOTFOUND
QT_WORLDTIMECLOCKPLUGIN_PLUGIN_RELEASE:FILEPATH=QT_WORLDTIMECLOCKPLUGIN_PLUGIN_RELEASE-NOTFOUND
TBB_DEBUG_LIBRARY:FILEPATH=TBB_DEBUG_LIBRARY-NOTFOUND
//Path to a file.
TBB_INCLUDE_DIR:PATH=TBB_INCLUDE_DIR-NOTFOUND
//Intel TBB install directory
TBB_INSTALL_DIR:PATH=/Library/Frameworks/Intel_TBB.framework/Versions
TBB_MALLOCPROXY_DEBUG_LIBRARY:FILEPATH=TBB_MALLOCPROXY_DEBUG_LIBRARY-NOTFOUND
TBB_MALLOCPROXY_RELEASE_LIBRARY:FILEPATH=TBB_MALLOCPROXY_RELEASE_LIBRARY-NOTFOUND
TBB_MALLOC_DEBUG_LIBRARY:FILEPATH=TBB_MALLOC_DEBUG_LIBRARY-NOTFOUND
TBB_MALLOC_RELEASE_LIBRARY:FILEPATH=TBB_MALLOC_RELEASE_LIBRARY-NOTFOUND
TBB_RELEASE_LIBRARY:FILEPATH=TBB_RELEASE_LIBRARY-NOTFOUND
Triangulation_demo_3_BINARY_DIR:STATIC=/Users/nchenavier/cgal/CGAL-4.6/demo/Triangulation_3/build
Triangulation_demo_3_SOURCE_DIR:STATIC=/Users/nchenavier/cgal/CGAL-4.6/demo/Triangulation_3
# INTERNAL cache entries
//ADVANCED property for variable: Boost_DEBUG
Boost_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CGAL_Boost_USE_STATIC_LIBS
CGAL_Boost_USE_STATIC_LIBS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_AR
CMAKE_AR-ADVANCED:INTERNAL=1
//This is the directory where this CMakeCache.txt was created
CMAKE_CACHEFILE_DIR:INTERNAL=/Users/nchenavier/cgal/CGAL-4.6/demo/Triangulation_3/build
//Major version of cmake used to create the current loaded cache
CMAKE_CACHE_MAJOR_VERSION:INTERNAL=3
//Minor version of cmake used to create the current loaded cache
CMAKE_CACHE_MINOR_VERSION:INTERNAL=2
//Patch version of cmake used to create the current loaded cache
CMAKE_CACHE_PATCH_VERSION:INTERNAL=2
//ADVANCED property for variable: CMAKE_COLOR_MAKEFILE
CMAKE_COLOR_MAKEFILE-ADVANCED:INTERNAL=1
//Path to CMake executable.
CMAKE_COMMAND:INTERNAL=/usr/local/Cellar/cmake/3.2.2/bin/cmake
//Path to cpack program executable.
CMAKE_CPACK_COMMAND:INTERNAL=/usr/local/Cellar/cmake/3.2.2/bin/cpack
//Path to ctest program executable.
CMAKE_CTEST_COMMAND:INTERNAL=/usr/local/Cellar/cmake/3.2.2/bin/ctest
//ADVANCED property for variable: CMAKE_CXX_COMPILER
CMAKE_CXX_COMPILER-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_CXX_FLAGS
CMAKE_CXX_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_CXX_FLAGS_DEBUG
CMAKE_CXX_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_CXX_FLAGS_MINSIZEREL
CMAKE_CXX_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_CXX_FLAGS_RELEASE
CMAKE_CXX_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_CXX_FLAGS_RELWITHDEBINFO
CMAKE_CXX_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_COMPILER
CMAKE_C_COMPILER-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_FLAGS
CMAKE_C_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_FLAGS_DEBUG
CMAKE_C_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_FLAGS_MINSIZEREL
CMAKE_C_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_FLAGS_RELEASE
CMAKE_C_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_C_FLAGS_RELWITHDEBINFO
CMAKE_C_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//Path to cache edit program executable.
CMAKE_EDIT_COMMAND:INTERNAL=/usr/local/Cellar/cmake/3.2.2/bin/ccmake
//Executable file format
CMAKE_EXECUTABLE_FORMAT:INTERNAL=Unknown
//ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS
CMAKE_EXE_LINKER_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_DEBUG
CMAKE_EXE_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_MINSIZEREL
CMAKE_EXE_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_RELEASE
CMAKE_EXE_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO
CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_EXPORT_COMPILE_COMMANDS
CMAKE_EXPORT_COMPILE_COMMANDS-ADVANCED:INTERNAL=1
//Name of external makefile project generator.
CMAKE_EXTRA_GENERATOR:INTERNAL=
//Name of generator.
CMAKE_GENERATOR:INTERNAL=Unix Makefiles
//Name of generator platform.
CMAKE_GENERATOR_PLATFORM:INTERNAL=
//Name of generator toolset.
CMAKE_GENERATOR_TOOLSET:INTERNAL=
//Start directory with the top level CMakeLists.txt file for this
// project
CMAKE_HOME_DIRECTORY:INTERNAL=/Users/nchenavier/cgal/CGAL-4.6/demo/Triangulation_3
//ADVANCED property for variable: CMAKE_INSTALL_NAME_TOOL
CMAKE_INSTALL_NAME_TOOL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_LINKER
CMAKE_LINKER-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MAKE_PROGRAM
CMAKE_MAKE_PROGRAM-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS
CMAKE_MODULE_LINKER_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_DEBUG
CMAKE_MODULE_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL
CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_RELEASE
CMAKE_MODULE_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO
CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_NM
CMAKE_NM-ADVANCED:INTERNAL=1
//number of local generators
CMAKE_NUMBER_OF_LOCAL_GENERATORS:INTERNAL=1
//ADVANCED property for variable: CMAKE_OBJCOPY
CMAKE_OBJCOPY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_OBJDUMP
CMAKE_OBJDUMP-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_RANLIB
CMAKE_RANLIB-ADVANCED:INTERNAL=1
//Path to CMake installation.
CMAKE_ROOT:INTERNAL=/usr/local/Cellar/cmake/3.2.2/share/cmake
//ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS
CMAKE_SHARED_LINKER_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_DEBUG
CMAKE_SHARED_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL
CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_RELEASE
CMAKE_SHARED_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO
CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SKIP_INSTALL_RPATH
CMAKE_SKIP_INSTALL_RPATH-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_SKIP_RPATH
CMAKE_SKIP_RPATH-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_STATIC_LINKER_FLAGS
CMAKE_STATIC_LINKER_FLAGS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_STATIC_LINKER_FLAGS_DEBUG
CMAKE_STATIC_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_STATIC_LINKER_FLAGS_MINSIZEREL
CMAKE_STATIC_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_STATIC_LINKER_FLAGS_RELEASE
CMAKE_STATIC_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_STATIC_LINKER_FLAGS_RELWITHDEBINFO
CMAKE_STATIC_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_STRIP
CMAKE_STRIP-ADVANCED:INTERNAL=1
//uname command
CMAKE_UNAME:INTERNAL=/usr/bin/uname
//ADVANCED property for variable: CMAKE_USE_RELATIVE_PATHS
CMAKE_USE_RELATIVE_PATHS-ADVANCED:INTERNAL=1
//ADVANCED property for variable: CMAKE_VERBOSE_MAKEFILE
CMAKE_VERBOSE_MAKEFILE-ADVANCED:INTERNAL=1
//Details about finding OpenGL
FIND_PACKAGE_MESSAGE_DETAILS_OpenGL:INTERNAL=[/System/Library/Frameworks/OpenGL.framework][/System/Library/Frameworks/OpenGL.framework][v()]
//Details about finding Qt4
FIND_PACKAGE_MESSAGE_DETAILS_Qt4:INTERNAL=[/usr/local/bin/qmake][/usr/local/Cellar/qt/4.8.6/bin/moc][/usr/local/Cellar/qt/4.8.6/bin/rcc][/usr/local/Cellar/qt/4.8.6/bin/uic][/usr/local/Cellar/qt/4.8.6/include;/usr/local/Cellar/qt/4.8.6/lib/QtCore.framework][/usr/local/Cellar/qt/4.8.6/lib][optimized;/usr/local/Cellar/qt/4.8.6/lib/QtCore.framework;debug;/usr/local/Cellar/qt/4.8.6/lib/QtCore.framework][v4.8.6()]
//ADVANCED property for variable: OPENGL_INCLUDE_DIR
OPENGL_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: OPENGL_gl_LIBRARY
OPENGL_gl_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: OPENGL_glu_LIBRARY
OPENGL_glu_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_ARTHURPLUGIN_PLUGIN_DEBUG
QT_ARTHURPLUGIN_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_ARTHURPLUGIN_PLUGIN_RELEASE
QT_ARTHURPLUGIN_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
QT_BINARY_DIR:INTERNAL=/usr/local/Cellar/qt/4.8.6/bin
//ADVANCED property for variable: QT_CONTAINEREXTENSION_PLUGIN_DEBUG
QT_CONTAINEREXTENSION_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_CONTAINEREXTENSION_PLUGIN_RELEASE
QT_CONTAINEREXTENSION_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_CUSTOMWIDGETPLUGIN_PLUGIN_DEBUG
QT_CUSTOMWIDGETPLUGIN_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_CUSTOMWIDGETPLUGIN_PLUGIN_RELEASE
QT_CUSTOMWIDGETPLUGIN_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_DBUSCPP2XML_EXECUTABLE
QT_DBUSCPP2XML_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_DBUSXML2CPP_EXECUTABLE
QT_DBUSXML2CPP_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_DESIGNER_EXECUTABLE
QT_DESIGNER_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_DOC_DIR
QT_DOC_DIR-ADVANCED:INTERNAL=1
QT_HEADERS_DIR:INTERNAL=/usr/local/Cellar/qt/4.8.6/include
//ADVANCED property for variable: QT_IMPORTS_DIR
QT_IMPORTS_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_LIBRARY_DIR
QT_LIBRARY_DIR-ADVANCED:INTERNAL=1
//Qt library dir
QT_LIBRARY_DIR:INTERNAL=/usr/local/Cellar/qt/4.8.6/lib
//ADVANCED property for variable: QT_LINGUIST_EXECUTABLE
QT_LINGUIST_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_LRELEASE_EXECUTABLE
QT_LRELEASE_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_LUPDATE_EXECUTABLE
QT_LUPDATE_EXECUTABLE-ADVANCED:INTERNAL=1
//Have symbol QT_MAC_USE_COCOA
QT_MAC_USE_COCOA:INTERNAL=1
//ADVANCED property for variable: QT_MKSPECS_DIR
QT_MKSPECS_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_MOC_EXECUTABLE
QT_MOC_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_PHONONWIDGETS_PLUGIN_DEBUG
QT_PHONONWIDGETS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_PHONONWIDGETS_PLUGIN_RELEASE
QT_PHONONWIDGETS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_PHONON_INCLUDE_DIR
QT_PHONON_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_PHONON_LIBRARY
QT_PHONON_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_PHONON_LIBRARY_DEBUG
QT_PHONON_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_PHONON_LIBRARY_RELEASE
QT_PHONON_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_PHONON_QT7_PLUGIN_DEBUG
QT_PHONON_QT7_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_PHONON_QT7_PLUGIN_RELEASE
QT_PHONON_QT7_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_PLUGINS_DIR
QT_PLUGINS_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QCNCODECS_PLUGIN_DEBUG
QT_QCNCODECS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QCNCODECS_PLUGIN_RELEASE
QT_QCNCODECS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QCOLLECTIONGENERATOR_EXECUTABLE
QT_QCOLLECTIONGENERATOR_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QCOREWLANBEARER_PLUGIN_DEBUG
QT_QCOREWLANBEARER_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QCOREWLANBEARER_PLUGIN_RELEASE
QT_QCOREWLANBEARER_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QDECLARATIVEVIEW_PLUGIN_DEBUG
QT_QDECLARATIVEVIEW_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QDECLARATIVEVIEW_PLUGIN_RELEASE
QT_QDECLARATIVEVIEW_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QDECORATIONDEFAULT_PLUGIN_DEBUG
QT_QDECORATIONDEFAULT_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QDECORATIONDEFAULT_PLUGIN_RELEASE
QT_QDECORATIONDEFAULT_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QDECORATIONWINDOWS_PLUGIN_DEBUG
QT_QDECORATIONWINDOWS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QDECORATIONWINDOWS_PLUGIN_RELEASE
QT_QDECORATIONWINDOWS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QGENERICBEARER_PLUGIN_DEBUG
QT_QGENERICBEARER_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QGENERICBEARER_PLUGIN_RELEASE
QT_QGENERICBEARER_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QGIF_PLUGIN_DEBUG
QT_QGIF_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QGIF_PLUGIN_RELEASE
QT_QGIF_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QGLGRAPHICSSYSTEM_PLUGIN_DEBUG
QT_QGLGRAPHICSSYSTEM_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QGLGRAPHICSSYSTEM_PLUGIN_RELEASE
QT_QGLGRAPHICSSYSTEM_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QICO_PLUGIN_DEBUG
QT_QICO_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QICO_PLUGIN_RELEASE
QT_QICO_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QIMSW_MULTI_PLUGIN_DEBUG
QT_QIMSW_MULTI_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QIMSW_MULTI_PLUGIN_RELEASE
QT_QIMSW_MULTI_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QJPCODECS_PLUGIN_DEBUG
QT_QJPCODECS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QJPCODECS_PLUGIN_RELEASE
QT_QJPCODECS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QJPEG_PLUGIN_DEBUG
QT_QJPEG_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QJPEG_PLUGIN_RELEASE
QT_QJPEG_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QKRCODECS_PLUGIN_DEBUG
QT_QKRCODECS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QKRCODECS_PLUGIN_RELEASE
QT_QKRCODECS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
QT_QMAKE_EXECUTABLE_LAST:INTERNAL=/usr/local/bin/qmake
//ADVANCED property for variable: QT_QMNG_PLUGIN_DEBUG
QT_QMNG_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QMNG_PLUGIN_RELEASE
QT_QMNG_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QNATIVEWIFIBEARER_PLUGIN_DEBUG
QT_QNATIVEWIFIBEARER_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QNATIVEWIFIBEARER_PLUGIN_RELEASE
QT_QNATIVEWIFIBEARER_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLDB2_PLUGIN_DEBUG
QT_QSQLDB2_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLDB2_PLUGIN_RELEASE
QT_QSQLDB2_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLIBASE_PLUGIN_DEBUG
QT_QSQLIBASE_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLIBASE_PLUGIN_RELEASE
QT_QSQLIBASE_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLITE2_PLUGIN_DEBUG
QT_QSQLITE2_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLITE2_PLUGIN_RELEASE
QT_QSQLITE2_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLITE_PLUGIN_DEBUG
QT_QSQLITE_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLITE_PLUGIN_RELEASE
QT_QSQLITE_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLMYSQL_PLUGIN_DEBUG
QT_QSQLMYSQL_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLMYSQL_PLUGIN_RELEASE
QT_QSQLMYSQL_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLOCI_PLUGIN_DEBUG
QT_QSQLOCI_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLOCI_PLUGIN_RELEASE
QT_QSQLOCI_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLODBC_PLUGIN_DEBUG
QT_QSQLODBC_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLODBC_PLUGIN_RELEASE
QT_QSQLODBC_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLPSQL_PLUGIN_DEBUG
QT_QSQLPSQL_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLPSQL_PLUGIN_RELEASE
QT_QSQLPSQL_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLTDS_PLUGIN_DEBUG
QT_QSQLTDS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSQLTDS_PLUGIN_RELEASE
QT_QSQLTDS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSVGICON_PLUGIN_DEBUG
QT_QSVGICON_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSVGICON_PLUGIN_RELEASE
QT_QSVGICON_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSVG_PLUGIN_DEBUG
QT_QSVG_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QSVG_PLUGIN_RELEASE
QT_QSVG_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QT3SUPPORTWIDGETS_PLUGIN_DEBUG
QT_QT3SUPPORTWIDGETS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QT3SUPPORTWIDGETS_PLUGIN_RELEASE
QT_QT3SUPPORTWIDGETS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QT3SUPPORT_INCLUDE_DIR
QT_QT3SUPPORT_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QT3SUPPORT_LIBRARY
QT_QT3SUPPORT_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QT3SUPPORT_LIBRARY_DEBUG
QT_QT3SUPPORT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QT3SUPPORT_LIBRARY_RELEASE
QT_QT3SUPPORT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTACCESSIBLECOMPATWIDGETS_PLUGIN_DEBUG
QT_QTACCESSIBLECOMPATWIDGETS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTACCESSIBLECOMPATWIDGETS_PLUGIN_RELEASE
QT_QTACCESSIBLECOMPATWIDGETS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTACCESSIBLEWIDGETS_PLUGIN_DEBUG
QT_QTACCESSIBLEWIDGETS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTACCESSIBLEWIDGETS_PLUGIN_RELEASE
QT_QTACCESSIBLEWIDGETS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTASSISTANTCLIENT_INCLUDE_DIR
QT_QTASSISTANTCLIENT_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTASSISTANTCLIENT_LIBRARY
QT_QTASSISTANTCLIENT_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTASSISTANTCLIENT_LIBRARY_DEBUG
QT_QTASSISTANTCLIENT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTASSISTANTCLIENT_LIBRARY_RELEASE
QT_QTASSISTANTCLIENT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTASSISTANT_INCLUDE_DIR
QT_QTASSISTANT_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTASSISTANT_LIBRARY
QT_QTASSISTANT_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTASSISTANT_LIBRARY_DEBUG
QT_QTASSISTANT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTASSISTANT_LIBRARY_RELEASE
QT_QTASSISTANT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTCLUCENE_LIBRARY
QT_QTCLUCENE_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTCLUCENE_LIBRARY_DEBUG
QT_QTCLUCENE_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTCLUCENE_LIBRARY_RELEASE
QT_QTCLUCENE_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTCORE_INCLUDE_DIR
QT_QTCORE_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTCORE_LIBRARY
QT_QTCORE_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTCORE_LIBRARY_DEBUG
QT_QTCORE_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTCORE_LIBRARY_RELEASE
QT_QTCORE_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDBUS_INCLUDE_DIR
QT_QTDBUS_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDBUS_LIBRARY
QT_QTDBUS_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDBUS_LIBRARY_DEBUG
QT_QTDBUS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDBUS_LIBRARY_RELEASE
QT_QTDBUS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDECLARATIVE_INCLUDE_DIR
QT_QTDECLARATIVE_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDECLARATIVE_LIBRARY
QT_QTDECLARATIVE_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDECLARATIVE_LIBRARY_DEBUG
QT_QTDECLARATIVE_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDECLARATIVE_LIBRARY_RELEASE
QT_QTDECLARATIVE_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDESIGNERCOMPONENTS_INCLUDE_DIR
QT_QTDESIGNERCOMPONENTS_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDESIGNERCOMPONENTS_LIBRARY
QT_QTDESIGNERCOMPONENTS_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDESIGNERCOMPONENTS_LIBRARY_DEBUG
QT_QTDESIGNERCOMPONENTS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDESIGNERCOMPONENTS_LIBRARY_RELEASE
QT_QTDESIGNERCOMPONENTS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDESIGNER_INCLUDE_DIR
QT_QTDESIGNER_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDESIGNER_LIBRARY
QT_QTDESIGNER_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDESIGNER_LIBRARY_DEBUG
QT_QTDESIGNER_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTDESIGNER_LIBRARY_RELEASE
QT_QTDESIGNER_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTGA_PLUGIN_DEBUG
QT_QTGA_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTGA_PLUGIN_RELEASE
QT_QTGA_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTGUI_INCLUDE_DIR
QT_QTGUI_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTGUI_LIBRARY
QT_QTGUI_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTGUI_LIBRARY_DEBUG
QT_QTGUI_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTGUI_LIBRARY_RELEASE
QT_QTGUI_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTHELP_INCLUDE_DIR
QT_QTHELP_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTHELP_LIBRARY
QT_QTHELP_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTHELP_LIBRARY_DEBUG
QT_QTHELP_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTHELP_LIBRARY_RELEASE
QT_QTHELP_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTIFF_PLUGIN_DEBUG
QT_QTIFF_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTIFF_PLUGIN_RELEASE
QT_QTIFF_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTMULTIMEDIA_INCLUDE_DIR
QT_QTMULTIMEDIA_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTMULTIMEDIA_LIBRARY
QT_QTMULTIMEDIA_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTMULTIMEDIA_LIBRARY_DEBUG
QT_QTMULTIMEDIA_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTMULTIMEDIA_LIBRARY_RELEASE
QT_QTMULTIMEDIA_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTNETWORK_INCLUDE_DIR
QT_QTNETWORK_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTNETWORK_LIBRARY
QT_QTNETWORK_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTNETWORK_LIBRARY_DEBUG
QT_QTNETWORK_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTNETWORK_LIBRARY_RELEASE
QT_QTNETWORK_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTNSPLUGIN_INCLUDE_DIR
QT_QTNSPLUGIN_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTNSPLUGIN_LIBRARY
QT_QTNSPLUGIN_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTNSPLUGIN_LIBRARY_DEBUG
QT_QTNSPLUGIN_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTNSPLUGIN_LIBRARY_RELEASE
QT_QTNSPLUGIN_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTOPENGL_INCLUDE_DIR
QT_QTOPENGL_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTOPENGL_LIBRARY
QT_QTOPENGL_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTOPENGL_LIBRARY_DEBUG
QT_QTOPENGL_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTOPENGL_LIBRARY_RELEASE
QT_QTOPENGL_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTRACEGRAPHICSSYSTEM_PLUGIN_DEBUG
QT_QTRACEGRAPHICSSYSTEM_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTRACEGRAPHICSSYSTEM_PLUGIN_RELEASE
QT_QTRACEGRAPHICSSYSTEM_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSCRIPTDBUS_PLUGIN_DEBUG
QT_QTSCRIPTDBUS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSCRIPTDBUS_PLUGIN_RELEASE
QT_QTSCRIPTDBUS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSCRIPTTOOLS_INCLUDE_DIR
QT_QTSCRIPTTOOLS_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSCRIPTTOOLS_LIBRARY
QT_QTSCRIPTTOOLS_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSCRIPTTOOLS_LIBRARY_DEBUG
QT_QTSCRIPTTOOLS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSCRIPTTOOLS_LIBRARY_RELEASE
QT_QTSCRIPTTOOLS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSCRIPT_INCLUDE_DIR
QT_QTSCRIPT_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSCRIPT_LIBRARY
QT_QTSCRIPT_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSCRIPT_LIBRARY_DEBUG
QT_QTSCRIPT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSCRIPT_LIBRARY_RELEASE
QT_QTSCRIPT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSQL_INCLUDE_DIR
QT_QTSQL_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSQL_LIBRARY
QT_QTSQL_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSQL_LIBRARY_DEBUG
QT_QTSQL_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSQL_LIBRARY_RELEASE
QT_QTSQL_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSVG_INCLUDE_DIR
QT_QTSVG_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSVG_LIBRARY
QT_QTSVG_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSVG_LIBRARY_DEBUG
QT_QTSVG_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTSVG_LIBRARY_RELEASE
QT_QTSVG_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTTEST_INCLUDE_DIR
QT_QTTEST_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTTEST_LIBRARY
QT_QTTEST_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTTEST_LIBRARY_DEBUG
QT_QTTEST_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTTEST_LIBRARY_RELEASE
QT_QTTEST_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTUITOOLS_INCLUDE_DIR
QT_QTUITOOLS_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTUITOOLS_LIBRARY
QT_QTUITOOLS_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTUITOOLS_LIBRARY_DEBUG
QT_QTUITOOLS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTUITOOLS_LIBRARY_RELEASE
QT_QTUITOOLS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTWCODECS_PLUGIN_DEBUG
QT_QTWCODECS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTWCODECS_PLUGIN_RELEASE
QT_QTWCODECS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTWEBKIT_INCLUDE_DIR
QT_QTWEBKIT_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTWEBKIT_LIBRARY
QT_QTWEBKIT_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTWEBKIT_LIBRARY_DEBUG
QT_QTWEBKIT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTWEBKIT_LIBRARY_RELEASE
QT_QTWEBKIT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTXMLPATTERNS_INCLUDE_DIR
QT_QTXMLPATTERNS_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTXMLPATTERNS_LIBRARY
QT_QTXMLPATTERNS_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTXMLPATTERNS_LIBRARY_DEBUG
QT_QTXMLPATTERNS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTXMLPATTERNS_LIBRARY_RELEASE
QT_QTXMLPATTERNS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTXML_INCLUDE_DIR
QT_QTXML_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTXML_LIBRARY
QT_QTXML_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTXML_LIBRARY_DEBUG
QT_QTXML_LIBRARY_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QTXML_LIBRARY_RELEASE
QT_QTXML_LIBRARY_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QWEBVIEW_PLUGIN_DEBUG
QT_QWEBVIEW_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QWEBVIEW_PLUGIN_RELEASE
QT_QWEBVIEW_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QWSTSLIBMOUSEHANDLER_PLUGIN_DEBUG
QT_QWSTSLIBMOUSEHANDLER_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_QWSTSLIBMOUSEHANDLER_PLUGIN_RELEASE
QT_QWSTSLIBMOUSEHANDLER_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_RCC_EXECUTABLE
QT_RCC_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_TASKMENUEXTENSION_PLUGIN_DEBUG
QT_TASKMENUEXTENSION_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_TASKMENUEXTENSION_PLUGIN_RELEASE
QT_TASKMENUEXTENSION_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_TRANSLATIONS_DIR
QT_TRANSLATIONS_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_UIC3_EXECUTABLE
QT_UIC3_EXECUTABLE-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_UIC_EXECUTABLE
QT_UIC_EXECUTABLE-ADVANCED:INTERNAL=1
QT_USE_FRAMEWORKS:INTERNAL=ON
//ADVANCED property for variable: QT_WORLDTIMECLOCKPLUGIN_PLUGIN_DEBUG
QT_WORLDTIMECLOCKPLUGIN_PLUGIN_DEBUG-ADVANCED:INTERNAL=1
//ADVANCED property for variable: QT_WORLDTIMECLOCKPLUGIN_PLUGIN_RELEASE
QT_WORLDTIMECLOCKPLUGIN_PLUGIN_RELEASE-ADVANCED:INTERNAL=1
//Have symbol Q_WS_MAC
Q_WS_MAC:INTERNAL=1
//Have symbol Q_WS_QWS
Q_WS_QWS:INTERNAL=
//Have symbol Q_WS_WIN
Q_WS_WIN:INTERNAL=
//Have symbol Q_WS_X11
Q_WS_X11:INTERNAL=
//ADVANCED property for variable: TBB_DEBUG_LIBRARY
TBB_DEBUG_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: TBB_INCLUDE_DIR
TBB_INCLUDE_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: TBB_INSTALL_DIR
TBB_INSTALL_DIR-ADVANCED:INTERNAL=1
//ADVANCED property for variable: TBB_MALLOCPROXY_DEBUG_LIBRARY
TBB_MALLOCPROXY_DEBUG_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: TBB_MALLOCPROXY_RELEASE_LIBRARY
TBB_MALLOCPROXY_RELEASE_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: TBB_MALLOC_DEBUG_LIBRARY
TBB_MALLOC_DEBUG_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: TBB_MALLOC_RELEASE_LIBRARY
TBB_MALLOC_RELEASE_LIBRARY-ADVANCED:INTERNAL=1
//ADVANCED property for variable: TBB_RELEASE_LIBRARY
TBB_RELEASE_LIBRARY-ADVANCED:INTERNAL=1
- [cgal-discuss] install cgal/qglviewer on mac, Olivier Devillers, 06/12/2015
