- To:
- Subject: Re: [cgal-discuss] CGAL installation
- Date: Wed, 22 Jul 2015 11:16:01 +0200
On 07/22/2015 11:13 AM, Audrey wrote:
Thanks Sebastien. I have already check in "Visual Studio --> Tools --> Visual
Studio Command Prompt" and I got :
C/C++ Optimizing Compiler Version 17.00.51106.1 for x86
So for me the compiler I have to use is 32 bit and I have thus to follow the
installation for 32 bit in the tutorial
http://www.cgal.org/download/windows.html#BuildingCGAL, is it right ?
For the library boost, I have also to install it in 32 bit ?! *but Is it not
a problem then to run my project with a Solutions Platform x64 because CGAL
and Boost will be in 32 bit ? *
All the more as I also use in my project some other libraries like eigen and
openCV which are already installed in 64 bit so I'm afraid that there is
some conflict with CGAL ....
Thanks,
Audrey
If you have both compilers, then select the 64bit one in cmake.
Sebastien.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/CGAL-installation-tp3910882p4661017.html
- Re: [cgal-discuss] CGAL installation, Audrey, 07/22/2015
- Re: [cgal-discuss] CGAL installation, Dylan Lawrence, 07/22/2015
- Re: [cgal-discuss] CGAL installation, Sebastien Loriot (GeometryFactory), 07/22/2015
