- To:
- Subject: [cgal-discuss] Poblems on Make_Mesh_3
- Date: Fri, 31 Jul 2015 20:16:59 +0800 (GMT+08:00)
Dear all
I have encountered a problem when I run the Make_mesh_3 function in CGAL.
And the output is listed as below. Can anyone can help me?
Thank you very much.
(23,10,0,0) (121.7 vertices/s)
Total refining surface time: 0.082236s
Start volume scan...Scanning triangulation for bad cells (sequential)... 57 cells scanned, done.
Number of bad cells: 6
end scan. [Bad tets:6]
Refining...
Legend of the following line: (#vertices,#steps,#facets to refine,#tets to refine)
(23,0,0,6)terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: !r_tr_.is_infinite(*cell_it)
File: ../../../myLibs/CGAL-4.6.1/include/CGAL/Mesh_3/Refine_cells_3.h
Line: 867
The program has unexpectedly finished.
- [cgal-discuss] Poblems on Make_Mesh_3, 11硕博 隋伟, 07/31/2015
- Re: [cgal-discuss] Poblems on Make_Mesh_3, Sebastien Loriot (GeometryFactory), 07/31/2015
- [cgal-discuss] Reply: Re: Poblems on Make_Mesh_3, 11硕博 隋伟, 07/31/2015
