- To:
- Subject: Re: [cgal-discuss] Bug Report: Setup 4.2 fails to download taucs library
- Date: Fri, 7 Aug 2015 03:26:07 -0700 (PDT)
Hi,
I am also facing issues while trying to install CGAL-4.6.1 behind proxy on
Windows 7 SP1(32-bit). Specifically, installer is not able to download GMP
and MPFR. Following Laurent's suggestion I have configured Internet Explorer
to correct proxy settings and I am able to access internet.
Installer reports(excerpts only):
gmp-all-CGAL-3.9.zip downloaded successfully.
mpfr-all-CGAL-3.9.zip downloaded successfully.
Extracting contents of C:\Program
Files\CGAL-4.6.1\auxiliary\gmp\mpfr-all-CGAL-3.9.zip to C:\Program
Error: ^¦Ä
Files\CGAL-4.6.1\auxiliary\gmp\gmp-all-CGAL-3.9.zip to C:\Program
Error: ^€
Completed
As can be seen it reports that GMP and MPFR are downloaded successfully but
these files are actually empty. I also would like to add that installer does
ask for proxy details before attempting to download mpfr and gmp.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Bug-Report-Setup-4-2-fails-to-download-taucs-library-tp4658131p4661050.html
- Re: [cgal-discuss] Bug Report: Setup 4.2 fails to download taucs library, Pranav, 08/07/2015
