- To:
- Subject: Re: [cgal-discuss] c++14 compatibility: CGAL::get and std::get ambiguity
- Date: Tue, 11 Aug 2015 09:12:07 +0200
- Organization: TU Dresden, Institut f. Automatisierungstechnik
Hello Marc
glad to see that it is already taken care of in the current beta and sorry for the noise about it.
Also thanks for pointing out ADL in this context. I wasn't aware that base was a std::pair. Now the compiler behavior makes perfect sense again.
Am 11.08.2015 um 04:48 schrieb Marc Glisse:
On Fri, 7 Aug 2015, Martin Seemann wrote:
I recently came across a regression, which is demonstrated by the
example below:
#include <CGAL/Simple_cartesian.h>
int main() {
typedef CGAL::Simple_cartesian<double> K;
CGAL::Line_3<K> line(CGAL::Point_3<K>(0, 0, 0),
CGAL::Point_3<K>(1, 1, 1));
std::cout << line.point(0) << std::endl;
return 0; }
Using GCC 5.2.0 (Archlinux), the above example compiles fine with
-std=c++11 but when switching to -std=c++14, the compiler starts
complaining about ambiguous 'get(...)' overloads in
CGAL/Cartesian/Line_3.h:78.
I figured that it was caused by some c++14 additions to the standard
library (http://en.cppreference.com/w/cpp/utility/pair/get, overloads
4-7).
A quick fix is to make the desired namespace explicit in
CGAL/Cartesian/Line_3.h, i. e. to replace lines 78 and 83 by
return CGAL::get(base).first;
and
return CGAL::get(base).second;
respectively.
After these modifications, the above example (and also my real
project) compiles fine.
https://github.com/CGAL/cgal/commit/b7f98495991ee49b2b01e64a36bb3b5c1e89a615
However, prefixing with CGAL:: in this place seems strange to me,
since we are already in namespace CGAL. Furthermore, I do not
understand why the std::get variants even participate in overload
resolution, given that they are defined in std (I couldn't find any
dangerous
'using namespace std' anywhere in the CGAL code base either).
Maybe someone with a deeper understanding of the language can give his
opinion if this situation should be corrected in CGAL or in the
standard library.
BTW: The error also happens with clang (v3.6.2)
(My CGAL version is 4.6.2)
ADL means that if the arguments involve a type defined in namespace std
(even indirectly), std::get gets to participate.
- [cgal-discuss] c++14 compatibility: CGAL::get and std::get ambiguity, Martin Seemann, 08/07/2015
- Re: [cgal-discuss] c++14 compatibility: CGAL::get and std::get ambiguity, Marc Glisse, 08/11/2015
- Re: [cgal-discuss] c++14 compatibility: CGAL::get and std::get ambiguity, Martin Seemann, 08/11/2015
