- To:
- Subject: Re: [cgal-discuss] Perfect forwarding of Delaunay_Triangulations
- Date: Fri, 21 Aug 2015 06:38:07 +0200 (CEST)
On Thu, 20 Aug 2015, Adam Getchell wrote:
I’m looking to create a perfect forwarding constructor which takes a
Delaunay_Triangulation_3 as an argument.
As I understand it, that would require Delaunay_Triangulation_3 to have a
move constructor and move assignment operator.
Are these defined?
I see the copy constructor defined on line 243 of
Triangulation_3/include/CGAL/Delaunay_triangulation_3.h. Would (near there)
be an appropriate place to add a move constructor, if one does not exist?
https://github.com/CGAL/cgal/issues/34
It may be easier to remove the copy constructor.
Then you still need to handle the base classes of course.
Should I use https://github.com/CGAL/cgal or
https://github.com/CGAL/cgal-public-dev?
First one.
Marc Glisse
- [cgal-discuss] Perfect forwarding of Delaunay_Triangulations, Adam Getchell, 08/21/2015
- Re: [cgal-discuss] Perfect forwarding of Delaunay_Triangulations, Marc Glisse, 08/21/2015
