- To:
- Subject: [cgal-discuss] Merge polylines
- Date: Fri, 21 Aug 2015 09:17:05 +0200
Dear list Is there some way in CGAL to merge nearly identical/overlapping 3D polylines? For instance if I would have two polylines of the same circle but faceted slightly differently: is there I way I could with a specified (distance error) tolerance, merge these 2 polylines into one or detect that they are "identical"? A more complicated example is two squares sharing one edge, but faceted differently along the shared edge. The goal of this operation is to remove problematic 1D features for 3D mesh generation. Bryn On 20.08.2015 16:55, Bryn Lloyd wrote:
Hi CGAL users and devs |
- [cgal-discuss] Make mesh with features: feature lines duplicated, overlapping or very close, Bryn Lloyd, 08/20/2015
- [cgal-discuss] Merge polylines, Bryn Lloyd, 08/21/2015
- Re: [cgal-discuss] Merge polylines, Sebastien Loriot (GeometryFactory), 08/24/2015
- Re: [cgal-discuss] Merge polylines, Bryn Lloyd, 08/24/2015
- Re: [cgal-discuss] Merge polylines, Laurent Rineau (CGAL/GeometryFactory), 08/25/2015
