- To:
- Subject: Re: [cgal-discuss] make_mesh_3 with features: initial points for C3T3
- Date: Tue, 01 Sep 2015 16:09:15 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:avDKKByy5FAD6GPXCy+O+j09IxM/srCxBDY+r6Qd0e0WIJqq85mqBkHD//Il1AaPBtWHraocwLaK+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6anHS+4HYoFwnlMkItf6KuStKU15z8i7z60qaQSjsLrQL1Wal1IhSyoFeZnegtqqwmFJwMzADUqGBDYeVcyDAgD1uSmxHh+pX4p8Y7oGwD884mosVPWKG/c6UjRqFDFxwnNXo07Yvlr0rtVwyKszE4W3gMnxxUSzLE6hzzQ9+xmQTTkq1S1S6fMNHsXJ49Uiil9bYqAle8jC4aLTM/7CfNi8p9hb9zqx2oo1p42YGCM9LdD+Z3Yq6IJYBSfmFGRMsEDyE=
Le Tuesday 01 September 2015 10:26:56 Bryn Lloyd a écrit :
> Dear CGAL/Mesh_3 users and developers
> I have an implicit domain oracle (derived from Labeled_mesh_domain_3)
> with 1D features.
> When I add features to my domain, make_mesh_3 sometimes does not
> discover my domain at all. Without the features the domain is discovered
> (usually).
> Digging into the code of make_mesh_3 I noticed the strategy to add
> initial points seems very different for a mesh with features
> (init_c3t3_with_features) compared to one without features (init_c3t3).
> This is how I understand it:
> No features:
> - segments between random points on sphere and "center" are
> intersected with domain - intersection points are added to C3T3
> With features:
> - features (0D,1D) are sampled and points added to C3T3 with
> "protecting balls"
> Conclusions:
> - So it seems the code for domains with features might oversee (partial)
> regions with no features.
> - Also, I guess, if a point on a feature is considered "outside" by the
> oracle, instead of on a surface patch, regions/domains will be missed.
I agree that this code path is surprising.
The issue is that the points returned by the functor Construct_initial_points
might be in the set of protecting balls of features, or close to that set.
> How to solve this?
> - Would it make sense to run the initialization code to add feature
> points and the add my own internal (dimension=3) points?
> - How should I add these points? Can I add the points via
> C3T3::insert(Point), or should I add them via the
> C3T3::insert(Weighted_point)
> - What weight/ball radius should I use? I don't really want to enforce
> these points, but want to help the oracle discover the domains.
Instead of:
C3t3 c3t3 = CGAL::make_mesh_3, can you undocumented functions:
C3t3 c3t3;
CGAL::internal::Mesh_3::init_c3t3_with_features(c3t3,domain,criteria);
Then here if you want to insert your own initial points *on the boundary of
the domain*, you can use:
typedef C3t3::Triangulation::Point Weighted_point;
const Weighted_point p(Weighted_point::Point(x, y, z));
Tr::Vertex_handle vh = c3t3.triangulation().insert(p);
c3t3.set_dimension(vh, 2);
If the points you insert are on 1D features, the `set_dimension` call should
specify 1 instead of 2.
Then you can call `refine_mesh_3` as usual:
CGAL::refine_mesh_3<C3t3>(c3t3, domain, criteria);
I am willing to improve the API of Mesh_3, to allow custom initialization of
the triangulation. What do you think could be a good API?
Laurent Rineau, PhD
- [cgal-discuss] make_mesh_3 with features: initial points for C3T3, Bryn Lloyd, 09/01/2015
- Re: [cgal-discuss] make_mesh_3 with features: initial points for C3T3, Benjamin Kehlet, 09/01/2015
- Re: [cgal-discuss] make_mesh_3 with features: initial points for C3T3, Bryn Lloyd, 09/01/2015
- Re: [cgal-discuss] make_mesh_3 with features: initial points for C3T3, Laurent Rineau (CGAL/GeometryFactory), 09/01/2015
