cgal-discuss - Re: [cgal-discuss] make_mesh_3 with features: initial points for C3T3
  • To:
  • Subject: Re: [cgal-discuss] make_mesh_3 with features: initial points for C3T3
  • Date: Tue, 1 Sep 2015 17:14:52 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-phdr: 9a23:h/QjvhJFh4zDOfRsY9mcpTZWNBhigK39O0sv0rFitYgUKfrxwZ3uMQTl6Ol3ixeRBMOAu64C07Kd7vuocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWC04Lvj6vvoNX6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86Fpy8kVWqrze+E0TKdTES89G2Ez/szi8xfZHiWV4X5JeH8HlFJsBw/U4FmuWpP2oyfSt/Z8w2+XIc3kC7s0D2fxp5x3QQPl3X9UfwUy93va35R9
Hi Laurent
Thanks for your example code and suggestions.
I have now implemented the "sampling" by adding points inside the domain (i.e. dimension=3) and it seems to work.
Would it be better to add intersection points on the surface (dim=2)?
Regarding the API, I could image a slight change to the Construct_initial_points helper struct, which might allow to add non-conflicting points.
If the struct would receive a "filter" predicate function to avoid adding nearby points, we could modify "init_c3t3" to something like this:
Initial_points_vector initial_points;
domain.construct_initial_points_object( Filter(c3t3) )(std::back_inserter(initial_points));
where Filter could be something like:
struct Filter
Filter(const C3t3& c3t3);
bool operator()(const Point& p) const;
Then init_c3t3 could be called after adding the "feature points".
Bryn
On 9/1/2015 4:09 PM, Laurent Rineau (CGAL/GeometryFactory) wrote:
Le Tuesday 01 September 2015 10:26:56 Bryn Lloyd a écrit :
Dear CGAL/Mesh_3 users and developers
I have an implicit domain oracle (derived from Labeled_mesh_domain_3)
with 1D features.
When I add features to my domain, make_mesh_3 sometimes does not
discover my domain at all. Without the features the domain is discovered
(usually).
Digging into the code of make_mesh_3 I noticed the strategy to add
initial points seems very different for a mesh with features
(init_c3t3_with_features) compared to one without features (init_c3t3).
This is how I understand it:
No features:
- segments between random points on sphere and "center" are
intersected with domain - intersection points are added to C3T3
With features:
- features (0D,1D) are sampled and points added to C3T3 with
"protecting balls"
Conclusions:
- So it seems the code for domains with features might oversee (partial)
regions with no features.
- Also, I guess, if a point on a feature is considered "outside" by the
oracle, instead of on a surface patch, regions/domains will be missed.
I agree that this code path is surprising.
The issue is that the points returned by the functor Construct_initial_points
might be in the set of protecting balls of features, or close to that set.
How to solve this?
- Would it make sense to run the initialization code to add feature
points and the add my own internal (dimension=3) points?
- How should I add these points? Can I add the points via
C3T3::insert(Point), or should I add them via the
C3T3::insert(Weighted_point)
- What weight/ball radius should I use? I don't really want to enforce
these points, but want to help the oracle discover the domains.
Instead of:
C3t3 c3t3 = CGAL::make_mesh_3, can you undocumented functions:
C3t3 c3t3;
CGAL::internal::Mesh_3::init_c3t3_with_features(c3t3,domain,criteria);
Then here if you want to insert your own initial points *on the boundary of
the domain*, you can use:
typedef C3t3::Triangulation::Point Weighted_point;
const Weighted_point p(Weighted_point::Point(x, y, z));
Tr::Vertex_handle vh = c3t3.triangulation().insert(p);
c3t3.set_dimension(vh, 2);
If the points you insert are on 1D features, the `set_dimension` call should
specify 1 instead of 2.
Then you can call `refine_mesh_3` as usual:
CGAL::refine_mesh_3<C3t3>(c3t3, domain, criteria);
I am willing to improve the API of Mesh_3, to allow custom initialization of
the triangulation. What do you think could be a good API?
