- To:
- Subject: Re: [cgal-discuss] Isosurfaces from Gray level image
- Date: Fri, 25 Sep 2015 06:43:42 -0700 (PDT)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Neutral ; spf=None
- Ironport-phdr: 9a23:msyMyxHTQRY39NRU6ndv6p1GYnF86YWxBRYc798ds5kLTJ75o8+wAkXT6L1XgUPTWs2DsrQf27aQ7/CrBz1IyK3CmU5BWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYsExnyfTB4Ov7yUtaLyZ/ni6buq9aNMk1hv3mUX/BbFF2OtwLft80b08NJC50a7V/3mEZOYPlc3mhyJFiezF7W78a0+4N/oWwL46pyv50IbaKvdKsxSflUDS8tLnsuzMztrxjKCwWVtVUGVWBDux5FEwHD4Av3FrP4qib8u6Ip3CCCMMv7ZasoUDKs6L1nDhLklXFUZHYC7GjLh5ko3+pgqxW7qkknzg==
Hi Jane,
Actually my first try was with Mesh_3 and he did the job as I wanted... for
small 3D samples. My final goal is to have a volumetric mesh for simulation.
However, once I work on my real 300x300x300 image, it takes forever. After
10h, it was still at the first step (point generation). I have tried to play
with loose parameters to make it faster but it didn't change.
That's why I decided to try 3D surface mesh first.
Thanks
Alexandre
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Isosurfaces-from-Gray-level-image-tp4661158p4661161.html
- [cgal-discuss] Isosurfaces from Gray level image, Alexandre Lapene, 09/25/2015
- Re: [cgal-discuss] Isosurfaces from Gray level image, Jane Tournois, 09/25/2015
- Re: [cgal-discuss] Isosurfaces from Gray level image, Alexandre Lapene, 09/25/2015
- Re: [cgal-discuss] Isosurfaces from Gray level image, Alexandre Lapene, 09/29/2015
