cgal-discuss - Re: [cgal-discuss] Isosurfaces from Gray level image
  • To:
  • Subject: Re: [cgal-discuss] Isosurfaces from Gray level image
  • Date: Fri, 25 Sep 2015 16:57:31 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-phdr: 9a23:gkeIMRyP1dnne6XXCy+O+j09IxM/srCxBDY+r6Qd0e8SIJqq85mqBkHD//Il1AaPBtWHra4UwLqP+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6anHS+4HYoFwnlMkItf6KuStKU05T8h7n60qaQSjsLrQL1Wal1IhSyoFeZnegtqqwmFJwMzADUqGBDYeVcyDAgD1uSmxHh+pX4p8Y7oGwD884mosVPWKG/c6UjRqFDFxwnNXo07Yvlr0rtVwyKs1kVVGherh1VGQ7C7QqyCpX4tCa8qu1gwi+dPNbeQr0zXDm+9bZlQRT0jz0WcTU+9TeE2YRLkKtHrUf59FREyInObdTNOQ==
I'm surprised, it should not be that bad...
how many vertices do you get after 10 hours?
can you please send me some data so that I can figure out what is going wrong?
thanks,
Jane.
Le 25/09/2015 15:43, Alexandre Lapene a écrit :
Hi Jane,
Actually my first try was with Mesh_3 and he did the job as I wanted... for
small 3D samples. My final goal is to have a volumetric mesh for simulation.
However, once I work on my real 300x300x300 image, it takes forever. After
10h, it was still at the first step (point generation). I have tried to play
with loose parameters to make it faster but it didn't change.
That's why I decided to try 3D surface mesh first.
Thanks
Alexandre
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Isosurfaces-from-Gray-level-image-tp4661158p4661161.html
Jane Tournois, PhD
R&D Engineer at GeometryFactory
http://www.geometryfactory.com/
