cgal-discuss - [cgal-discuss] Wrong inexact intersection between 3D triangles
  • To:
  • Subject: [cgal-discuss] Wrong inexact intersection between 3D triangles
  • Date: Mon, 5 Oct 2015 16:59:16 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:JzjV8xagfMAblMoJN7zFf3r/LSx+4OfEezUN459isYplN5qZpcm+bnLW6fgltlLVR4KTs6sC0LqK9f6wEjxYqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLsh7z0pc2YM10ArQH+SI0xBS3+lR/WuMgSjNkqAYcK4TyNnEF1ff9Lz3hjP1OZkkW0zM6x+Jl+73YY4Kp5pIYTGZn9Kq83RLgdADU9OH0u/+XqswPCRE2B/CgySGITxyZIAgHK61nfX5P4tCbmqu014yKaOczqUbQ5Q3z286dqQRDvjTxcHzE8+WDTzMd3ifQI81qauxVjztuMM8muP/1kc/aFcA==
Hello!
   I'm having a really weird bug when trying to intersect two triangles inside a 3D space while using the `CGAL::Exact_predicates_inexact_constructions_kernel` kernel. Essentially, I have two triangles that should not intersect. The function `CGAL::do_intersect` returns always `false` when testing them, but the function `CGAL::intersection` builds an intersection, depending on the order of the vertices of the triangles.
   The bug disappears when I use the `CGAL::Exact_predicates_exact_constructions_kernel` kernel, but I can't afford to use it in the real case scenario.
   Below is a minimal code with the bug. Triangles B and C are equal (up to a permutation of the vertices), and should return the same intersection with Triangle A.
    #include <CGAL/Intersections.h>
    #include <iostream>
    #include <vector>
    typedef CGAL::Exact_predicates_inexact_constructions_kernel Kernel;
    typedef Kernel::Point_3 Point_3;
    typedef Kernel::Triangle_3  Triangle_3;
    int main(int argc, char *argv[])
        std::vector<Point_3> APoints(3);
        std::vector<Point_3> BPoints(3);
        APoints[0] = Point_3(2, 2, 0.9423616295572568);
        APoints[1] = Point_3(0.9685134704003172, 2, 0.9678422992674797);
        APoints[2] = Point_3(2, 1.124710354419025, 1.068692504586136);
        BPoints[0] = Point_3(2.5, 2.5, 1.442361629557257);
        BPoints[1] = Point_3(1.588259113885977, 2.5, 0.5);
        BPoints[2] = Point_3(2.5, 1.624710354419025, 1.568692504586136);
        Triangle_3 TriangleA(APoints[0],APoints[1],APoints[2]);
        Triangle_3 TriangleB(BPoints[0],BPoints[1],BPoints[2]);
        Triangle_3 TriangleC(BPoints[2],BPoints[1],BPoints[0]);
    std::cout.precision(16);
    std::cout << "   - Tried to intersect: " << std::endl;
    std::cout << "   - Triangle (A) " << " : "
    << "(" << TriangleA.vertex(0) << ") "
    << "(" << TriangleA.vertex(1) << ") "
    << "(" << TriangleA.vertex(2) << ") " << std::endl;
    std::cout << "   - Triangle (B) " << " : "
    << "(" << TriangleB.vertex(0) << ") "
    << "(" << TriangleB.vertex(1) << ") "
    << "(" << TriangleB.vertex(2) << ") " << std::endl;
    std::cout << "   - Triangle (C) " << " : "
    << "(" << TriangleC.vertex(0) << ") "
    << "(" << TriangleC.vertex(1) << ") "
    << "(" << TriangleC.vertex(2) << ") " << std::endl;
    if( TriangleB.vertex(0)==TriangleC.vertex(2) &&
            TriangleB.vertex(1)==TriangleC.vertex(1) &&
            TriangleB.vertex(2)==TriangleC.vertex(0))
    std::cout << "   - Triangles (B) and (C) have the same vertices " << std::endl;
        bool bIntersectAB = CGAL::do_intersect(TriangleA,TriangleB);
        bool bIntersectAC = CGAL::do_intersect(TriangleA,TriangleC);
        bool bIntersectInexactAB = CGAL::intersection(TriangleA,TriangleB);
        bool bIntersectInexactAC = CGAL::intersection(TriangleA,TriangleC);
        if(bIntersectAB)
        std::cout << " --> A and B are intersecting (exact) ..." << std::endl;
        if(bIntersectAC)
        std::cout << " --> A and C are intersecting (exact) ..." << std::endl;
        if(bIntersectInexactAB)
        std::cout << " --> A and B are intersecting (inexact) ..." << std::endl;
        if(bIntersectInexactAC)
        std::cout << " --> A and C are intersecting (inexact) ..." << std::endl;
    return 0;
Here's the output ...
       - Triangle (A)  : (2 2 0.9423616295572568) (0.9685134704003172 2 0.9678422992674797) (2 1.124710354419025 1.068692504586136)
       - Triangle (B)  : (2.5 2.5 1.442361629557257) (1.588259113885977 2.5 0.5) (2.5 1.624710354419025 1.568692504586136)
       - Triangle (C)  : (2.5 1.624710354419025 1.568692504586136) (1.588259113885977 2.5 0.5) (2.5 2.5 1.442361629557257)
Does anyone have any idea about what could be happening? I’m using CGAL 4.6.1, on OS X 10.10.5 (Yosemite).
Thanks in advance,
Thiago Milanetto Schlittler
