- To:
- Subject: Re: [cgal-discuss] Isosurfaces from Gray level image
- Date: Mon, 5 Oct 2015 12:10:19 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23:t3JQ8xR2p4rYGyMHh8zFFRxs9tpsv+yvbD5Q0YIujvd0So/mwa64YRCN2/xhgRfzUJnB7Loc0qyN4/ymBzxLu87JmUtBWaIPfidNsd8RkQ0kDZzNImzAB9muURYHGt9fXkRu5XCxPBsdMs//Y1rPvi/6tmZKSV3BPAZ4bt74BpTVx5zukbvip9uNM04S3HKUWvBbElaflU3prM4YgI9veO4a6yDihT92QdlQ3n5iPlmJnhzxtY+a9Z9n9DlM6bp6r5YTGfayQ6NtRrNRCHEqMns++dbwnRjFVwqGoHUGAUsMlR8dIQHD4VnGWYrrtCz7raIp2iCcMIvqSq0uXzOj9I9kRRjthTsdJjAw+33QkN02h6Ve9kHy7ydjypLZNdnGfMF1ebnQKIsX
Hi,
facet_distance=0.2 works fine, and 0.1 indeed takes very long
Do you know the size of your voxels? Maybe it's not really possible to reach such an accuracy(?)
Jane.
Le 03/10/2015 00:48, Alexandre Lapene a écrit :
Finally, if I just change facet_distance from 1 to 0.1. It's still taking a
while
Thanks
Alexandre
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Isosurfaces-from-Gray-level-image-tp4661158p4661183.html
Jane Tournois, PhD
R&D Engineer at GeometryFactory
http://www.geometryfactory.com/
- Re: [cgal-discuss] Isosurfaces from Gray level image, Jane Tournois, 10/02/2015
- Re: [cgal-discuss] Isosurfaces from Gray level image, Alexandre Lapene, 10/02/2015
- Re: [cgal-discuss] Isosurfaces from Gray level image, Alexandre Lapene, 10/03/2015
- Re: [cgal-discuss] Isosurfaces from Gray level image, Jane Tournois, 10/05/2015
- Re: [cgal-discuss] Isosurfaces from Gray level image, Alexandre Lapene, 10/05/2015
- Re: [cgal-discuss] Isosurfaces from Gray level image, Jane Tournois, 10/06/2015
- Re: [cgal-discuss] Isosurfaces from Gray level image, Alexandre Lapene, 10/06/2015
- Re: [cgal-discuss] Isosurfaces from Gray level image, Jane Tournois, 10/08/2015
