RE: [cgal-discuss] Nef_polyhedron and Exact_predicates_inexact_constructions_kernel
- To: <>
- Subject: RE: [cgal-discuss] Nef_polyhedron and Exact_predicates_inexact_constructions_kernel
- Date: Wed, 7 Oct 2015 13:31:35 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:Bv8oXx2sRAjEyDX1smDT+DRfVm0co7zxezQtwd8ZsekWK/ad9pjvdHbS+e9qxAeQG96Lt7Qb0KGL6+jJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6kO74TNaIBjjLw09fr2zQd6OyZvsnL3qs7ToICx2xxOFKYtoKxu3qQiD/uI3uqBFbpgL9x3Sv3FTcP5Xz247bXianhL7+9vitMU7q3cY6Loc8dVdW/D6Y7ggVu4fSy83Nng8osztrxjKCwWVoWANV30f1RtODQ+C5x7zWtL9szDxq/FmixWdaJn9QrkwHDij9Kx2UwTAiSEdNjd//nuB2eJqi6cO6jesvRh+xcb5fJOSMPY0NvfYcMkeRGxIU9pDUChNKoy5ZooLSeEGOLAL/MHGu1ISoE7mVkGXD+T1x2oQiw==
Dear All,
I am working on the inverted problem of Thiago (I am interested what is left
after to polyhedrons are subtracted form each other) and have the same
issues as Thiago and Taus. Some clarification would be really great.
Please keep posting about any insights you may get, I will do the same as I
go along.
Best wishes,
Merlin :)
-----Original Message-----
[mailto:]
On Behalf Of Taus Møller
Sent: 07 October 2015 09:56
To:
Subject: Re: [cgal-discuss] Nef_polyhedron and
I have run into the same problem. I have a hard time know what kernel are
usable for what. Even though the exact and inexact construction kernel models
the same concepts, they seem to be different in some ways. I have found that
the Exact_predicates_exact_construction_kernel
works for use with with Nef_polyhedra_3.
On 2 October 2015 at 18:30, Thiago Milanetto Schlittler
wrote:
> Hello!
> I’m trying to use Nef polyhedrons to find the intersections between
> polyhedrons, and I’m having some problems. The compiler returns the
> following error when trying to convert a polyhedron to a nef_polyhedron:
> In file included from /opt/local/include/CGAL/Nef_3/SNC_k3_tree_traits.h:24:
> /opt/local/include/CGAL/Nef_3/Bounding_box_3.h:90:34: error: no member
> named 'lo' in 'CGAL::Box_intersection_d::Box_d<double, 3,
> CGAL::Box_intersection_d::ID_EXPLICIT>'
> std::copy( q, q + 3, Base::lo );
> I’m using the “Exact_predicates_inexact_constructions_kernel”,
> could this be the reason?
> Thanks in advance,
Regards
Taus Møller
Software Developer, Apiosoft
- [cgal-discuss] Nef_polyhedron and Exact_predicates_inexact_constructions_kernel, Thiago Milanetto Schlittler, 10/02/2015
- Re: [cgal-discuss] Nef_polyhedron and Exact_predicates_inexact_constructions_kernel, Taus Møller, 10/07/2015
- RE: [cgal-discuss] Nef_polyhedron and Exact_predicates_inexact_constructions_kernel, Merlin Etzold, 10/07/2015
- Re: [cgal-discuss] Nef_polyhedron and Exact_predicates_inexact_constructions_kernel, Sebastien Loriot (GeometryFactory), 10/07/2015
- Re: [cgal-discuss] Nef_polyhedron and Exact_predicates_inexact_constructions_kernel, Taus Møller, 10/08/2015
- Re: [cgal-discuss] Nef_polyhedron and Exact_predicates_inexact_constructions_kernel, Sebastien Loriot (GeometryFactory), 10/08/2015
- Re: [cgal-discuss] Nef_polyhedron and Exact_predicates_inexact_constructions_kernel, Thiago Milanetto Schlittler, 10/08/2015
