- To: "" <>
- Subject: Re: [cgal-discuss] dD Delaunay Triangulation, data dependent performance
- Date: Wed, 7 Oct 2015 16:18:46 +0200 (CEST)
On Wed, 7 Oct 2015, Scherrer Daniel wrote:
I experience huge differences in performance when triangulating in 6D. I
tested the following:
const int D = 6;
typedef CGAL::Epick_d<CGAL::Dimension_tag<D>> K;
typedef CGAL::Delaunay_triangulation<K> T;
for (int i = 0; i < 512; ++i){
points.push_back(T::Point((i & 0x3), (i & 0xc) >> 2, (i & 0x30)
>> 4,
(i & 0x40) >> 6, (i & 0x80) >> 7, (i & 0x100) >> 8));
T t(D);
t.insert(points.begin(), points.end());
This takes about 12s on my PC.
Then I tried the same but scaled the positions by 10 like this:
Try scaling by a power of 2 instead ;-)
points.push_back(T::Point((i & 0x3) * 10, ((i & 0xc) >> 2) * 10, ((i
& 0x30) >> 4) * 10,
((i & 0x40) >> 6) * 10, ((i & 0x80) >> 7) * 10, ((i &
0x100) >> 8) * 10));
And this takes more than 1 minute. The scaling itself does not seem to be the
problem. I tried different data sets which performed better or worse for no
obvious reason. I observed factors in computing time up to 30.
Any idea what the triangulation performance could depend on?
Predicates are first evaluated using interval arithmetic (a pair of double). In usual non-degenerate cases, it is often sufficient to get the sign of the polynomial. In degenerate situations (when the result is 0), it usually fails because we don't know the sign of an interval containing zero, and the computation is done again using an exact but slow number type. Except in one caseĀ : when all the interval computations were lucky enough to be exact and the interval is thus just one point, 0. This can happen in particular when all the coordinates are very small integers.
Marc Glisse
- [cgal-discuss] dD Delaunay Triangulation, data dependent performance, Scherrer Daniel, 10/07/2015
- Re: [cgal-discuss] dD Delaunay Triangulation, data dependent performance, Marc Glisse, 10/07/2015
- RE: [cgal-discuss] dD Delaunay Triangulation, data dependent performance, Scherrer Daniel, 10/08/2015
- RE: [cgal-discuss] dD Delaunay Triangulation, data dependent performance, Marc Glisse, 10/08/2015
