- To:
- Subject: Re: [cgal-discuss] Problem with loading .off files in Polyhedron demo
- Date: Thu, 08 Oct 2015 14:25:24 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:wh3idx3yTLdKFP7+smDT+DRfVm0co7zxezQtwd8ZsegQLvad9pjvdHbS+e9qxAeQG96Lt7Qb1qGL6ejJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6kO74TNaIBjjLw09fr2zQd6OyZvqnL3os7ToICx2xxOFKYtoKxu3qQiD/uI3uqBFbpgL9x3Sv3FTcP5Xz247bXianhL7+9vitMU7q3cY6Lod8JtLXqz+Oqg5VrdFFy8OMmYv5cStuwOQYxGI4y5WaWgcmwFUAgXDpDX9RJb2rmO6med63SSGJ9zYRLsoXi6zru0jHATsjz0GMCJ/9WX/hcl5jaYdqxWk8U8si7XIaZ2YYaItNpjWeskXEDJM
On 10/08/2015 02:07 PM, LTH wrote:
Hi all, I've just downloaded CGAL 4.7 and compiled its demos in VS 2013.some plugins aren't loading?
However, when I run Polyhedron_3.exe to load an .off file, a small "Select a
loader" popup window appears in which I can't select anything. Did I miss
something here?
Best and Regards.
LTH.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Problem-with-loading-off-files-in-Polyhedron-demo-tp4661212.html
Any output in the console?
If a plugin cannot be loaded, run dependency walker on it to see what is missing.
Sebastien.
- [cgal-discuss] Problem with loading .off files in Polyhedron demo, LTH, 10/08/2015
- Re: [cgal-discuss] Problem with loading .off files in Polyhedron demo, Sebastien Loriot (GeometryFactory), 10/08/2015
- Re: [cgal-discuss] Problem with loading .off files in Polyhedron demo, LTH, 10/08/2015
