- To:
- Subject: Re: [cgal-discuss] Problem with loading .off files in Polyhedron demo
- Date: Thu, 08 Oct 2015 14:39:35 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:qrf5kh1jPo6A7xogsmDT+DRfVm0co7zxezQtwd8ZsegQLvad9pjvdHbS+e9qxAeQG96Lt7Qb1qGL6ejJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6kO74TNaIBjjLw09fr2zQd6OyZvqnL3os7ToICx2xxOFKYtoKxu3qQiD/uI3uqBFbpgL9x3Sv3FTcP5Xz247bXianhL7+9vitMU7q3cY6Lod8JtLXqz+Oqg5VrdFFy8OMmYv5cStuwOQYxGI4y5WaWgcmwFUAgXDpDX9RJb2rmO6med63SSGJ9zYRLsoXi6zru0jHATsjz0GMCJ/9WX/hcl5jaYdqxWk8U8si7XIaZ2YYaItNpjWeskXEDJM
On 10/08/2015 02:19 PM, LTH wrote:
Thanks for your quick reply. Here is what I get in the console window:you must compile off_plugin if you want to load off files.
Enable scripts.
# Looking for plugins in directory
"E:/Libraries/CGAL/build/demo/Polyhedron/Release"...
### Loading " polyhedron_slicer_plugin.dll "... success
### Loading " polyhedron_stitching_plugin.dll "... success
Succesfully loaded shader func 'VisibilityVP' in file 'Raycasting.glsl'
Succesfully loaded shader func 'VisibilityFP' in file 'Raycasting.glsl'
Succesfully loaded shader func 'AttributeVP' in file 'Raycasting.glsl'
Succesfully loaded shader func 'AttributeFP' in file 'Raycasting.glsl'
Succesfully loaded shader func 'Finalization' in file 'Finalization.glsl'
QWindowsNativeFileDialogBase::shellItem:
SHCreateItemFromParsingName(file:Release)) failed (No such file or
directory)
Best and Regards.
LTH.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Problem-with-loading-off-files-in-Polyhedron-demo-tp4661212p4661215.html
Sebastien.
- [cgal-discuss] Problem with loading .off files in Polyhedron demo, LTH, 10/08/2015
- Re: [cgal-discuss] Problem with loading .off files in Polyhedron demo, Sebastien Loriot (GeometryFactory), 10/08/2015
- Re: [cgal-discuss] Problem with loading .off files in Polyhedron demo, LTH, 10/08/2015
