- To:
- Subject: [cgal-discuss] Snap vertices in Nef_3 to integer coordinates
- Date: Thu, 8 Oct 2015 16:32:50 -0400
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:XRPdTxBGZfKeRMdstS8MUyQJP3N1i/DPJgcQr6AfoPdwSP7+o8bcNUDSrc9gkEXOFd2CrakU16yJ7uu5BT1IyK3CmU5BWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYsExnyfTB4Ov7yUtaLyZ/ni6btptaKP1QArQH+SI0xBS3+lR/WuMgSjNkqAYcK4TyNnEF1ff9Lz3hjP1OZkkW0zM6x+Jl+73YY4Kp5pIYTGZn9Kq83RLgdADU9OH0u/+XqswPCRE2B/CgySGITx1ByBALI9g2yYdG5kCz6sPFh3y+Xd4WiV/YrHzal76FwVBjuhQ8IMjc49Cfcjckm3/ETmw6ouxEqm92cW4qSLvcrJq4=
Hello Everyone,
I understand that there will likely be an impact on robustness, but I would like to know if there is a way to snap the coordinates of a Nef_3 to integer coordinates. The program will create the union of many polyhedra, which I'm planning to do with an exact kernel to avoid issues, and then post-process the resulting polyhedron to snap the vertices. Are there any suggestions to how this could be done efficiently?
Thank-you,
Robert
Robert W. Johnstone
In theory, there is no difference between theory and practice.
In practice, there is.
Robert W. Johnstone
- [cgal-discuss] Snap vertices in Nef_3 to integer coordinates, Robert W. Johnstone, 10/08/2015
- Re: [cgal-discuss] Snap vertices in Nef_3 to integer coordinates, Sebastien Loriot (GeometryFactory), 10/09/2015
- Re: [cgal-discuss] Snap vertices in Nef_3 to integer coordinates, Olivier Devillers, 10/09/2015
