- To:
- Subject: [cgal-discuss] Installation problem with CGAL-4.7beta2 on Ubuntu15
- Date: Sat, 17 Oct 2015 19:50:10 -0700 (PDT)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
- Ironport-phdr: 9a23:mDwmtBZnDktkCfAgUxyh1B7/LSx+4OfEezUN459isYplN5qZpcm4bnLW6fgltlLVR4KTs6sC0LqK9fG7EjVRsd6oizMrTt9lb1c9k8IYnggtUoauKHbQC7rUVRE8B9lIT1R//nu2YgB/Ecf6YEDO8DXptWZBUiv2OQc9HOnpAIma153xjLDuvcyIKFwZ1HKUWvBbElaflU3prM4YgI9veO4a6yDihT92QdlQ3n5iPlmJnhzxtY+a9Z9n9DlM6bp6r5YTGZPTJPppCOUARHR9azh0t4XXskzIQgKLo3cdSW4LiQFgAg7f7Ri8UI2inDH9s7900jebPtf/SPhgUD687qRxQRrAhyIONjp/+2bS3J8jxJlHqQ6s8kUsi7XfZ5uYYaEmJq4=
I am trying to install CGAL-4.7beta2 and installed all dependencies on Ubuntu
15 using the package manager.
I have also set export Qt5_DIR to point to the path to the directory
containing the file Qt5Config.cmake created by my Qt5 installation.
I can cmake the CGAL with no errors as below:
Configuring libCGAL_Qt5
libCGAL_Qt5 is configured
But when I "make" then it is showing below error:
/home/abhi/Downloads/CGAL-4.7-beta2/src/CGAL_Qt5/qrc_CGAL.cpp:3604:11:
error: invalid type in declaration before ‘;’ token
} dummy;
error: conflicting declaration ‘int {anonymous}::dummy’
In file included from
/home/abhi/Downloads/CGAL-4.7-beta2/src/CGAL_Qt5/all_files.cpp:1:0:
/home/abhi/Downloads/CGAL-4.7-beta2/src/CGAL_Qt5/qrc_Input.cpp:395:6: note:
previous declaration as ‘{anonymous}::initializer {anonymous}::dummy’
} dummy;
src/CGAL_Qt5/CMakeFiles/CGAL_Qt5.dir/build.make:110: recipe for target
'src/CGAL_Qt5/CMakeFiles/CGAL_Qt5.dir/all_files.cpp.o' failed
make[2]: *** [src/CGAL_Qt5/CMakeFiles/CGAL_Qt5.dir/all_files.cpp.o] Error 1
CMakeFiles/Makefile2:342: recipe for target
'src/CGAL_Qt5/CMakeFiles/CGAL_Qt5.dir/all' failed
make[1]: *** [src/CGAL_Qt5/CMakeFiles/CGAL_Qt5.dir/all] Error 2
Makefile:117: recipe for target 'all' failed
make: *** [all] Error 2
Any suggestion?
Thanks,
Abhi
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Installation-problem-with-CGAL-4-7beta2-on-Ubuntu15-tp4661245.html
- [cgal-discuss] Installation problem with CGAL-4.7beta2 on Ubuntu15, abvikram, 10/18/2015
