cgal-discuss - Re: [cgal-discuss] CGAL 4.7 Beta 2 Released, Computational Geometry Algorithms Library
  • To:
  • Subject: Re: [cgal-discuss] CGAL 4.7 Beta 2 Released, Computational Geometry Algorithms Library
  • Date: Sat, 17 Oct 2015 19:44:00 -0700 (PDT)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
  • Ironport-phdr: 9a23:eI8RBxTPx/iKB84NMJ29YQmwstpsv+yvbD5Q0YIujvd0So/mwa64ZxKN2/xhgRfzUJnB7Loc0qyN4/ymCDdLuMfR+Fk5M7VyFDY9wf0MmAIhBMPXQWbaF9XNKxIAIcJZSVV+9Gu6O0UGUOz3ZlnVv2HgpWVKQka3CwN5K6zPF5LIiIzvjqbpq8GVMl4D3WvtKZpJbzyI7izp/vEMhoVjLqtjgjDomVBvP9ps+GVzOFiIlAz97MrjtLRq8iBXpu5zv5UYCfayLOwESulTAz0idmw0/8b2rgLrTA2V53JaXH9FvABPBl3M5g/7XY34t2Ouv+Bj2SqANMjeQrU9WDDk5KBuHky7wBwbPiI0pTmEwvd7i7hW9Uqs
I am trying to install CGAL-4.7beta2 and installed all dependencies on Ubuntu
15 using the package manager.
I have also set export Qt5_DIR to point to the path to the directory
containing the file Qt5Config.cmake created by my Qt5 installation.
I can cmake the CGAL with no errors as below:
Configuring libCGAL_Qt5
libCGAL_Qt5 is configured
But when I "make" then it is showing below error:
/home/abhi/Downloads/CGAL-4.7-beta2/src/CGAL_Qt5/qrc_CGAL.cpp:3604:11:
error: invalid type in declaration before ‘;’ token
} dummy;
error: conflicting declaration ‘int {anonymous}::dummy’
In file included from
/home/abhi/Downloads/CGAL-4.7-beta2/src/CGAL_Qt5/all_files.cpp:1:0:
/home/abhi/Downloads/CGAL-4.7-beta2/src/CGAL_Qt5/qrc_Input.cpp:395:6: note:
previous declaration as ‘{anonymous}::initializer {anonymous}::dummy’
} dummy;
src/CGAL_Qt5/CMakeFiles/CGAL_Qt5.dir/build.make:110: recipe for target
'src/CGAL_Qt5/CMakeFiles/CGAL_Qt5.dir/all_files.cpp.o' failed
make[2]: *** [src/CGAL_Qt5/CMakeFiles/CGAL_Qt5.dir/all_files.cpp.o] Error 1
CMakeFiles/Makefile2:342: recipe for target
'src/CGAL_Qt5/CMakeFiles/CGAL_Qt5.dir/all' failed
make[1]: *** [src/CGAL_Qt5/CMakeFiles/CGAL_Qt5.dir/all] Error 2
Makefile:117: recipe for target 'all' failed
make: *** [all] Error 2
Any suggestion?
Thanks,
Abhi
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/CGAL-4-7-Beta-2-Released-Computational-Geometry-Algorithms-Library-tp4661155p4661244.html
  • Re: [cgal-discuss] CGAL 4.7 Beta 2 Released, Computational Geometry Algorithms Library, abvikram, 10/18/2015
