cgal-discuss - Re: [cgal-discuss] Cgal error while compiling
  • To:
  • Subject: Re: [cgal-discuss] Cgal error while compiling
  • Date: Tue, 20 Oct 2015 09:56:46 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:kVPa+hHWZL67GuIKLSA3CZ1GYnF86YWxBRYc798ds5kLTJ74psWwAkXT6L1XgUPTWs2DsrQf27aQ4v+rADVaqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLsh7z0qsKYOlwSzBOGIppMbzyO5T3LsccXhYYwYo0Q8TDu5kVyRuJN2GlzLkiSlRuvru25/Zpk7jgC86l5r50IAu3Heb8lR+lYECg+KDJyo9b6sAHKCwqJ/HoVFGsM1QFZBhDMqxD8UJC2uSTzsq9x2TKRINbtHowzDD+t5qMuRB7zgzocLBY49nvWg4p+lvF1uhWk8lZEzoTde52UOfw2WqTHfNQGDSpuU8FUWjBbE621ZJcIFftAd64MtI36vVoJsV27ASGjAeruznlDgXqgjv5y6PgoDQyThF9oJNkJqnmB9Ng=
I just checked and this function is inside the lib gmp.
You probably did not link with it or link with a non-valid one (32 vs
64bits?)
Sebastien.
On 10/19/2015 08:50 AM, Medhat Rashad Abdelsaber wrote:
Yes I had did
Sent by Outlook <http://taps.io/outlookmobile> for Android
On Sun, Oct 18, 2015 at 11:49 PM -0700, "Sebastien Loriot
(GeometryFactory)"
<mailto:>>
wrote:
Did you link with GMP?
On 10/17/2015 11:27 PM, Medhat Rashad Abdelsaber wrote:
I had get the latest CGAL on fedora 20
For using it in mesh segmentation but when I run it I get that error
In file Bbox_3_Segment_3_do_intersect.h
Multiple definition of main
File sdf_value_example.cpp
Undefined reference to '__gmpq_init'
_Thanks_
