- To: "" <>
- Subject: RE: [cgal-discuss] Crash by transforming Polyhedron_3 to Nef_Polyhedron_3
- Date: Fri, 23 Oct 2015 11:02:01 +0000
- Accept-language: de-CH, en-US
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23:mtZVbRZ5gduBytrA9Lp5ZJv/LSx+4OfEezUN459isYplN5qZpcq8bnLW6fgltlLVR4KTs6sC0LqL9fi+Ejddqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLsh730o8OYOFgArQH+SI0xBS3+lR/WuMgSjNkqAYcK4TyNnEF1ff9Lz3hjP1OZkkW0zM6x+Jl+73YY4Kp5pIYTGZn9Ku4zQrVcSTgnKGso/9bDtB/ZTALJ6GFWGjEdnRNMRgTE9xrnRYzZsy3gt+M71jPMbuPsSrVhejKv8rxwADDpjCMKLHZt02fal9dryo1zvBW7oRtkhYXTZdfGZ7JFYqrBcIZCFiJ6VcFLWnkZDw==
Hello Sebastien,
Setting the compilation flag CGAL_NDEBUG, the problem has disappeared !
(using compiler MinGW 4.8 32b, W7).
Have a nice week end.
Gilles
-----Message d'origine-----
De :
[mailto:]
De la part de Sebastien Loriot (GeometryFactory)
Envoyé : jeudi 22 octobre 2015 11:32
À :
Objet : Re: [cgal-discuss] Crash by transforming Polyhedron_3 to
Nef_Polyhedron_3
I won't because I think the error is in your code.
Have a look at the example I provided in my previous message and compare it
to the relevant part in your code.
Sebastien.
On 10/22/2015 11:27 AM, Kneuss Gilles wrote:
> Thank you.
> In case you have an idea, coming afterward, let me know !
> Have a nice day
> Gilles
> De :
> [mailto:]
> (GeometryFactory) Envoyé : jeudi 22 octobre 2015 11:05 À :
> No sorry no idea, I can load your input without problem as a Nef polyhedron.
> Sebastien.
> On 10/22/2015 10:14 AM, Kneuss Gilles wrote:
>> Sebastien,
>> I construct a simpler forme (a cube).
>> The screenshot look like this :
>> Giving a (simple) program you can compile will bring me hours of work !
>> Don’t you have a clue/a beginning of a clue, despite ?
>> Gilles
>> De :
>> [mailto:]
>> (GeometryFactory)
>> Envoyé : jeudi 22 octobre 2015 09:55
>> À :
>> Nef_Polyhedron_3
>> I don't understand.
>> In your first bug report you showed a screenshot that has nothing to
>> do with the input you provide in your latest message.
>> Could you please provide a minimal and complete program I can compile
>> and run, and that is showing the problem?
>> Thanks,
>> Sebastien.
>> On 10/22/2015 09:50 AM, Kneuss Gilles wrote:
>> > Sebastien,
>> > It's created inside the application, I do not save it to a file...
>> > After constructing a simple cube, this portion of code :
>> > voidPolyhedron_ac::/essai/(){
>> > Facet_const_iteratorf;
>> > intfacesN;
>> > facesN=1;
>> > for(f=facets_begin();f!=facets_end();f++){
>> > qDebug()<<"Face#"<<facesN++;
>> > //onparcourslespointsdelaface
>> > HF_circulatorhe=f->facet_begin();
>> > do{
>> > qDebug()<<"x:"<<CGAL::to_double(he->vertex()->point().x())
>> > <<";y:"<<CGAL::to_double(he->vertex()->point().y())
>> > <<";z:"<<CGAL::to_double(he->vertex()->point().z())<<";";
>> > while(++he!=f->facet_begin());
>> > if(this->is_closed()){
>> > Nef_polyhedrontempo(*this);//hereit'scrashing!
>> > …gives this output, just before it crashes :
>> > Face # 1
>> > x : -5 ; y : -5 ; z : 0 ;
>> > x : -5 ; y : 5 ; z : 0 ;
>> > x : 5 ; y : 5 ; z : 0 ;
>> > x : 5 ; y : -5 ; z : 0 ;
>> > Face # 2
>> > x : 5 ; y : -5 ; z : 10 ;
>> > x : 5 ; y : 5 ; z : 10 ;
>> > x : -5 ; y : 5 ; z : 10 ;
>> > x : -5 ; y : -5 ; z : 10 ;
>> > Face # 3
>> > Face # 4
>> > Face # 5
>> > Face # 6
>> > *Le programme s'est terminé subitement.*
>> > Gilles//
>> > De :
>> <mailto:>
>> [mailto:]
>> Loriot
>> > (GeometryFactory)
>> > Envoyé : jeudi 22 octobre 2015 09:00
>> > À :
>> <mailto:>
>> > Nef_Polyhedron_3
>> > On 10/22/2015 08:42 AM, Gilles wrote:
>> > > Hello Sébastien,
>> > > I can share anything !
>> > > What do you need ?
>> > the input polyhedron.
>> > Sebastien.
>> > > Gilles
>> > > View this message in context:
>> http://cgal-discuss.949826.n4.nabble.com/Crash-by-transforming-Polyhe
>> d
>> > > ron-3-to-Nef-Polyhedron-3-tp4661258p4661261.html
>> > > Sent from the cgal-discuss mailing list archive at Nabble.com.
>> > You are currently subscribed to cgal-discuss.
>> > To unsubscribe or access the archives, go to
>> > https://sympa.inria.fr/sympa/info/cgal-discuss
- [cgal-discuss] Crash by transforming Polyhedron_3 to Nef_Polyhedron_3, Gilles, 10/22/2015
- Re: [cgal-discuss] Crash by transforming Polyhedron_3 to Nef_Polyhedron_3, Sebastien Loriot (GeometryFactory), 10/22/2015
- Re: [cgal-discuss] Crash by transforming Polyhedron_3 to Nef_Polyhedron_3, Gilles, 10/22/2015
- RE: [cgal-discuss] Crash by transforming Polyhedron_3 to Nef_Polyhedron_3, Kneuss Gilles, 10/22/2015
- RE: [cgal-discuss] Crash by transforming Polyhedron_3 to Nef_Polyhedron_3, Kneuss Gilles, 10/23/2015
