Re: [cgal-discuss] CGAL 4.7 Released, Computational Geometry Algorithms Library
- To:
- Subject: Re: [cgal-discuss] CGAL 4.7 Released, Computational Geometry Algorithms Library
- Date: Thu, 22 Oct 2015 22:08:40 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:ehOrPRTIsLDlffn1C7/D2Xt/CNpsv+yvbD5Q0YIujvd0So/mwa64YBON2/xhgRfzUJnB7Loc0qyN4/2mATBLuMrd+Fk5M7VyFDY9wf0MmAIhBMPXQWbaF9XNKxIAIcJZSVV+9Gu6O0UGUOz3ZlnVv2HgpWVKQka3CwN5K6zPF5LIiIzvjqbpq8CVO1kD3WbhKZpJbzyI7izp/vEMhoVjLqtjgjDomVBvP9ps+GVzOFiIlAz97MrjtLRq8iBXpu5zv5UYCfayLOwESulTAz0idmw0/8b2rgLrTA2V53JaXH9FvABPBl3n6xjxXpb0+hH3t+F91S3Sac/xRLs0WDHk9apqQx/ljA8IMi5//GyB2Z84t75SvB/0/083+IXTeozAbPc=
On 10/20/2015 02:10 PM, Laurent Rineau (CGAL/GeometryFactory) wrote:
> The CGAL Open Source Project is pleased to announce the release 4.7
> of CGAL, the Computational Geometry Algorithms Library.
Debian packages for CGAL 4.7 are now available as well. Simply add
deb http://debian.cgal.org jessie main
deb-src http://debian.cgal.org jessie main
deb http://debian.cgal.org stretch main
deb-src http://debian.cgal.org stretch main
to /etc/apt/sources.list (you only need the pair of lines corresponding
to the release you are using). For sid, packages should be available
from the official Debian repository in a few days. The packages are called
libcgal11v5, libcgal-dev, libcgal-qt5-11, libcgal-qt5-dev, libcgal-demo, and
libcgal-ipelets.
In case you want to download the packages manually, have a look at
http://debian.cgal.org/pool/main/c/cgal/ .
See also http://www.cgal.org/FAQ.html#debian_packages .
Joachim
- [cgal-discuss] CGAL 4.7 Released, Computational Geometry Algorithms Library, Laurent Rineau (CGAL/GeometryFactory), 10/20/2015
- Re: [cgal-discuss] CGAL 4.7 Released, Computational Geometry Algorithms Library, Joachim Reichel, 10/22/2015
- Re: [cgal-discuss] CGAL 4.7 Released, Computational Geometry Algorithms Library, abvikram, 10/28/2015
- Re: [cgal-discuss] CGAL 4.7 Released, Computational Geometry Algorithms Library, Sebastien Loriot (GeometryFactory), 10/28/2015
- Re: [cgal-discuss] CGAL 4.7 Released, Computational Geometry Algorithms Library, abvikram, 10/29/2015
- Re: [cgal-discuss] CGAL 4.7 Released, Computational Geometry Algorithms Library, Laurent Rineau (CGAL/GeometryFactory), 10/29/2015
- Re: [cgal-discuss] CGAL 4.7 Released, Computational Geometry Algorithms Library, abvikram, 10/30/2015
