cgal-discuss - Re: [cgal-discuss] 3D Delaunay triangulation: nearest simplex on convex hull
  • To:
  • Subject: Re: [cgal-discuss] 3D Delaunay triangulation: nearest simplex on convex hull
  • Date: Thu, 29 Oct 2015 10:41:51 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-phdr: 9a23:OC/IUBy2NezJQWfXCy+O+j09IxM/srCxBDY+r6Qd0e8QIJqq85mqBkHD//Il1AaPBtWGrasVwLKN+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6anHS+4HYoFwnlMkItf6KuStOU1pX8j7v60qaQSjsLrQL1Wal1IhSyoFeZnegtqqwmFJwMzADUqGBDYeVcyDAgD1uSmxHh+pX4p8Y7oGwD884mosVPWKG/c6UjRqFDFxwnNXo07Yvlr0rtVwyKs0AdV2IQ2jVJGQHY4BbmFsPqsy79sKxy2TOTIMHxUZg7VDOn4rtxWRHhgzsALS9/+2bS3J8jxJlHqQ6s8kQsi7XfZ5uYYaJz
Le 28/10/2015 12:05, Olivier Devillers a écrit :
Le 28/10/15 11:54, Simon Giraudot a écrit :
Hello,
I am trying to access the nearest simplex (vertex, edge or facet) of a query point lying *outside* of the convex hull of the 3D Delaunay triangulation (this nearest simplex is thus adjacent to at least one infinite cell).
It seems difficult for several reasons:
* The infinite cells of a DT do not have a geometric meaning: locate() applied to an outside point returns "one" infinite cell, but it does not means that the point projects on the finite facet of this cell;
* The nearest_vertex() can give a hint but the nearest vertex of an outside point is not necesseraly on the convex hull.
Is there a simple/efficient way to do that?
My suggestion:
locate(p) return an infinite cell t;
while true
let t=abci (where i is infinite vertex)
v = oriented_normal(abc)
if orient(a,b,p,b+v)=cw { t=t->neighbor(through abi); continue;}
if orient(b,c,p,b+v)=cw { t=t->neighbor(through bci); continue;}
if orient(c,a,p,a+v)=cw { t=t->neighbor(through aci); continue;}
// the nearest facet on convex hull is abc
break;
in other words, walk on the convex hull facets until p project on the facet
(to be adapted to degenerate cases, of course)
Okay, it took me some time to figure out how to deal with edges/vertices but it seems to work fine now.
Thanks very much!
Simon Giraudot, PhD
R&D Engineer
GeometryFactory - http://geometryfactory.com/
