cgal-discuss - Re: [cgal-discuss] Maximum Distance from Bounding Volume Calculation
  • To:
  • Subject: Re: [cgal-discuss] Maximum Distance from Bounding Volume Calculation
  • Date: Tue, 3 Nov 2015 11:13:45 -0800 (PST)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Neutral ; spf=None
  • Ironport-phdr: 9a23:xTjsPREcQwqBkB0GUed/gZ1GYnF86YWxBRYc798ds5kLTJ75o82wAkXT6L1XgUPTWs2DsrQf27eQ6fCrBTJIyK3CmU5BWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYsExnyfTB4Ov7yUtaLyZ/niqboq9aPPU1hv3mUX/BbFF2OtwLft80b08NJC50a7V/3mEZOYPlc3mhyJFiezF7W78a0+4N/oWwL46pyv50IbaKvdKsxSflUDS8tLnsuzMztrxjKCwWVtVUGVWBDtxtDAwHI6FnZWp7trmOus+t22CCXOYv1SbkoRRys5rotRBK+23RPDCIw7GyC0p84t6lcuh/0/xE=
Dear Michael,
thank you very much for your help. Your solutions works perfectly.
Now, I need to generalize the program to three (and probably even higher)
dimensions.
I have found the package "dD Triangulations", but I am unsure how I can use
it to only construct the convex hull and determine the largest distance
between two points.
Thank you very much!
Best regards,
Michael
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Maximum-Distance-from-Bounding-Volume-Calculation-tp4661269p4661314.html
