- To:
- Subject: Re: [cgal-discuss] polygon intersection
- Date: Wed, 18 Nov 2015 08:59:15 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:u7yS/x2LgbicHiztsmDT+DRfVm0co7zxezQtwd8ZsegeKvad9pjvdHbS+e9qxAeQG96LtrQa06GP6vGocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWC0oLpj6vrosybSj4LrQT+SIs6FA+xowTVu5teqqpZAYF19CH0pGBVcf9d32JiKAHbtR/94sCt4MwrqHwI6LoX3pUfCuCiI+x4EOQZX3waNDU+68Tv8BXCVgCS/WA0U2MMkxMODRKWwgv9W8K7iSbwv/Fh2SScdenxV7EzRXziwKpsTRL0kjYpPjUl93vGy4Y42LlfpwigoAA5xor8b4ScNf44daTYK4BJDVFdV9pcAnQSSri3aJECWrdZMA==
The intersection function comes from the package
2D Regularized Boolean Set-Operations [1] where the operations
are regularized. In particular this implies that the intersection
of two polygons is ignored if its dimension is not 2.
Note that you must use a kernel with exact constructions such as CGAL:Exact_predicates_exact_constructions_kernel.
Sebastien.
[1] http://doc.cgal.org/latest/Boolean_set_operations_2/index.html
On 11/17/2015 10:00 PM, Hoang Giang Bui wrote:
Dear list
I have a question regarding the robustness of the intersection algorithm
of 2 polygons using CGAL. For the example below, CGAL failed to produce
the correct result
#include <iostream>
#include <CGAL/Simple_cartesian.h>
#include <CGAL/Polygon_2.h>
#include <CGAL/Polygon_with_holes_2.h>
#include <CGAL/Boolean_set_operations_2.h>
#include <CGAL/Polygon_2_algorithms.h>
int main(void)
double data1[] = {
-1.637348598514268e+01,-15,
-1.080050138869282e+01,-15,
-1.080050138869283e+01,15,
-1.637348598514268e+01,15};
double data2[] = {
-1.216086355952537e+01,15,
-1.216086355952538e+01,-15,
-6.925474894430892e+00,-15,
-6.925474894430885e+00,15
std::vector<Point> points;
for(int i = 0; i < 4; ++i)
points.push_back(Point(data1[2*i], data1[2*i+1]));
std::vector<Point> points2;
points2.push_back(Point(data2[2*i], data2[2*i+1]));
Polygon_2 poly1(points.begin(), points.end());
if(poly1.orientation() == CGAL::CLOCKWISE)
poly1.reverse_orientation();
std::cout << "poly1 is reversed" << std::endl;
Polygon_2 poly2(points2.begin(), points2.end());
if(poly2.orientation() == CGAL::CLOCKWISE)
poly2.reverse_orientation();
std::cout << "poly2 is reversed" << std::endl;
//CGAL::General_polygon_with_holes_2<K> poly3;
std::list<Polygon_with_holes_2> polyI;
CGAL::intersection(poly1, poly2, std::back_inserter(polyI));
double totalArea = 0;
typedef std::list<Polygon_with_holes_2>::iterator LIT;
for(LIT lit = polyI.begin(); lit != polyI.end(); ++lit)
totalArea += lit->outer_boundary().area();
std::cout << lit->outer_boundary() << std::endl;
std::cout << std::endl;
std::cout << "TotalArea: " << totalArea << std::endl;
If we change the data1 slightly to
double data1[] = {
-1.080050138869283e+01,-15,
The correct result is reproduced. This shows that the result is quite
sensitive with the input. Although this example is a degenerate case
where the rectangles are overlapping on horizontal edge. But I think the
intersection algorithm should be able to handle this. In case that is
the default behaviour of CGAL, what should I do to improve the result of
the degenerate case?
Giang Bui
- [cgal-discuss] polygon intersection, Hoang Giang Bui, 11/17/2015
- Re: [cgal-discuss] polygon intersection, Sebastien Loriot (GeometryFactory), 11/18/2015
- Re: [cgal-discuss] polygon intersection, Hoang Giang Bui, 11/19/2015
