cgal-discuss - [cgal-discuss] Faulty vertex normal transforming Polyhedron -> Nef Polyheron.
  • To:
  • Subject: [cgal-discuss] Faulty vertex normal transforming Polyhedron -> Nef Polyheron.
  • Date: Wed, 18 Nov 2015 02:08:17 -0800 (PST)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-phdr: 9a23:Drbnhx+ZNme6L/9uRHKM819IXTAuvvDOBiVQ1KB91+McTK2v8tzYMVDF4r011RmSDdidtasP0rGempujcFJDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBXsq3G/pQQfBg/4fVIsYL+lR8iM1o/ujKibwN76XUZhvHKFe7R8LRG7/036l/I9ps9cEJs30QbDuXBSeu5blitCLFOXmAvgtI/rpMYwuxJ54KxwspcYGeWhJ/x5HvRkC2EtPGkxocHqrhLeVhCn530GU2xQnAAbLRLC6UTVX5P1vzCy4ul71TSBJov5ZawzQzKl9OFgTxq+23RPDCIw7GyC0584t6lcuh/0/EQnzg==
Hello,
May be a newbie question !
To be able to achieve boolean operations, I have to transform *Polyhedron
into Nef Polyhedron* and from Nef Polyhedron once the boolean operation is
done.
The problem :
The way the transformation triangulate makes *faulty normals *(please look
at the image).
Is there a way to triangulate "properly" the polyhedron to avoid this
problem.
Thank you in advance
Best Regards.
Gilles
<http://cgal-discuss.949826.n4.nabble.com/file/n4661349/normals.png>
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Faulty-vertex-normal-transforming-Polyhedron-Nef-Polyheron-tp4661349.html
