- To:
- Subject: Re: [cgal-discuss] Boolean operations on triangular meshes
- Date: Wed, 18 Nov 2015 10:07:33 -0500
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23:EXD1+hwR6iQsaHjXCy+O+j09IxM/srCxBDY+r6Qd0ekeIJqq85mqBkHD//Il1AaPBtWGrawdwLSI+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6anHS+4HYoFwnlMkItf6KuStOU0Z38ib760qaQSjsLrQL1Wal1IhSyoFeZnegtqqwmFJwMzADUqGBDYeVcyDAgD1uSmxHh+pX4p8Y7oGwD884mosVPWKG/c6UjRqFDFxwnNXo07Yvlr0rtVwyKs14VSGQLiVJrAg7Z4RWyCpL4qCrnrcJ+2S+GMMmwS70oD2fxp5x3QQPl3X9UfwUy93va35R9
> On Nov 18, 2015, at 08:05 AM, Taus Møller
> wrote:
> In relation to robustness, before you convert to nef you have to be
> absolutely sure that you Polyhedron mesh is valid, closed and not self
> intersecting. If there is any kind of issue with the mesh, […]
I would add that Polyhedron_3 also requires all triangles to have a non-zero
area, as they require a valid normal vector (and calculate these normals
themselves). This is a very common problem when importing external meshes.
-Marius
- [cgal-discuss] Boolean operations on triangular meshes, SirM2X, 11/16/2015
- Re: [cgal-discuss] Boolean operations on triangular meshes, Taus Møller, 11/18/2015
- Re: [cgal-discuss] Boolean operations on triangular meshes, Marius Kintel, 11/18/2015
- Re: [cgal-discuss] Boolean operations on triangular meshes, SirM2X, 11/20/2015
- Re: [cgal-discuss] Boolean operations on triangular meshes, Sebastien Loriot (GeometryFactory), 11/20/2015
