cgal-discuss - Re: [cgal-discuss] Boolean operations on triangular meshes
  • To:
  • Subject: Re: [cgal-discuss] Boolean operations on triangular meshes
  • Date: Fri, 20 Nov 2015 08:33:44 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:Hltq4BHDtczfluuOrMtImJ1GYnF86YWxBRYc798ds5kLTJ75ociwAkXT6L1XgUPTWs2DsrQf27eQ7fyrCT1IyK3CmU5BWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYsExnyfTB4Ov7yUtaLyZ/niqbsp9aDMk1hv3mUX/BbFF2OtwLft80b08NJC50a7V/3mEZOYPlc3mhyJFiezF7W78a0+4N/oWwL46pyv50IbaKvdKsxSflUDS8tLnsuzMztrxjKCwWVtVUGVWBD2CFFCQHe8BD3WN/VtTH7sfY1mAaXOsj7Uaoldz2p86BxWV6iwHMcMzkj8WbLzMl0pK1eqROl4Rd4xtiHM8muKPNic/aFLpshTm1bU5MJWg==
CGAL provides a few functions that can help cleaning your mesh:
- polygon soup orientation
- self-intersection detection
- hole filling
- border stitching
They are all documented in the Polygon Mesh Processing package:
http://doc.cgal.org/latest/Polygon_mesh_processing/index.html
There is a non-documented alternative to Nef polyhedron called
corefinement that is shipped with CGAL.
In a few words your input must not be self-intersecting where
the input polyhedra intersects, and the intersection between the
surface must be a set of close curves (boundary might be used
to close the curves).
I join an example to see how it is working.
A non-official documentation:
https://cgal.geometryfactory.com/~sloriot/corefinement_doc/classCGAL_1_1Polyhedron__corefinement.html
Sebastien.
On 11/20/2015 12:18 AM, SirM2X wrote:
Taus,
Thank you very much for the detailed response. Especially, thanks for the
link to builder example. It will surely come in handy.
Regarding the Boolean operations, I wouldn't even think of implementing them
myself (toooo complicated).
So, if I understand everything correctly, CGAL won't be able to help me: the
meshes that I deal with are obtained using point cloud data and look
terrible (you can bet that they will have self-intersections, degeneracies,
and so on). Also, I'm sure many of the meshes that I use are not closed
(imagine a really bad 3D reconstruction of a ball and a box on a desk). I
can preprocess my meshes to remove degeneracies and self-intersections, but
I cannot guarantee that the mesh will be closed. So I'm assuming CGAL won't
work?
If the answer is no, then I may have to jettison the idea of using Boolean
operations for what I want to do.
Marius,
Thank you for the additional information.
Taus Møller wrote
I have been struggling (and still is) with this exact problem for
quite some time. There are quite a few issues and challenges in
relation to this, and the documentation is largely useless on the
issues related to use with C#. I have done boolean operations
successfully but continually struggle with making it robust.
First, my advice would be to actually make you own boolean operations.
At least if you need it for anything more than proof of concept. The
performance of boolean operations in CGAL is horrendous. I have tried
inquiring about method to speed them up, but it seem that is just the
way it is. As an example doing a simple union between two meshes of
around 400 triangles takes around 8 seconds, which is frankly
ridiculous. My understanding is that this performance is the price you
pay for having exact math in the calculation. This advantage is
however mostly lost due to the fact you pulling the meshes out of
CGAL. This is additionally compounded by the need to converted to and
from Nef polyhedra. We are primarily using CGAL because implementing
Booleans is hard(!) and we currently have the resources to do it.
Additionally, CGAL provides a lot of additional functionality that is
very convenient. Also, to be fair, it is my experience that appart
from booleans CGAL is actually very quick.
To convert to Polyhedron_3 i found the best way was to implement
Modifier_base as outlined here:
http://doc.cgal.org/4.7/Polyhedron/Polyhedron_2polyhedron_prog_incr_builder_8cpp-example.html.
This way you can provide you mesh as vertex list and triangle indices
and get a Polyhedron_3 from it.
In relation to robustness, before you convert to nef you have to be
absolutely sure that you Polyhedron mesh is valid, closed and not self
intersecting. If there is any kind of issue with the mesh, CGAL fails
in a very unhelpful way. I am currently struggling to ensure mesh
integrity on Polyhedron_3 meshes. CGAL does provide some useful
functionality for this, but still leaves a lot to be desired.
Hope it helps
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Boolean-operations-on-triangular-meshes-tp4661345p4661366.html
#include <CGAL/Polyhedron_3.h>
#include <CGAL/IO/Polyhedron_iostream.h>
#include <CGAL/corefinement_operations.h>
#include <CGAL/iterator.h>
#include <fstream>
#include <iostream>
typedef CGAL::Exact_predicates_inexact_constructions_kernel Kernel;
typedef CGAL::Polyhedron_3<Kernel> Polyhedron;
typedef CGAL::Polyhedron_corefinement<Polyhedron> Corefinement;
typedef std::vector<Kernel::Point_3> Polyline;
int main(int argc,char** argv)
  if (argc!=3){
    std::cerr << "Usage: " << argv[0] << "file1.off file2.off" << std::endl;
    return 1;
  //read input polyhedra
  Polyhedron A,B;
  std::ifstream input;
  input.open(argv[1]);
  if (!input) {std::cerr << "Error cannot read " << argv[1] << std::endl; return 1;}
  input >> A;
  input.close();
  input.open(argv[2]);
  if (!input) {std::cerr << "Error cannot read " << argv[2] << std::endl; return 1;}
  input >> B;
  input.close();
  //check validity of polyhedra
  if (!A.is_pure_triangle() || !B.is_pure_triangle()){
    std::cerr << "Inputs polyhedra must be triangulated." << std::endl;
    return 1;
  if (!A.size_of_vertices() || !B.size_of_vertices()){
    std::cerr << "Inputs polyhedra must not be empty." << std::endl;
    return 1;
  if (!A.is_valid() || !B.is_valid()){
    std::cerr << "Inputs polyhedra must be valid." << std::endl;
    return 1;
  //define the vector to contain result.
  std::vector<std::pair <Polyhedron*,int> > result;
  result.reserve(2);
  //Define the functor performing corefinement and boolean operations
  Corefinement coref;
  CGAL::Emptyset_iterator polyline_output;  //if you are interested by the intersection polyline,
  //                                          declare std::list<Polyline> polylines;  and use
  //                                          std::back_inserter(polylines) instead of polyline_output
  //run the corefinement. The sum of tags indicates we are interested in the union and the intersection of
  // the input polyhedra.
  coref(A,B,polyline_output,std::back_inserter(result),Corefinement::Join_tag | Corefinement::Intersection_tag);
  std::ofstream output;
  int union_index = result[0].second==Corefinement::Join_tag?0:1;
  int intersection_index = (union_index+1)%2;
  //write result into off files.
  output.open("union.off");
  output << *( result[union_index].first );
  output.close();
  output.open("intersection.off");
  output << *( result[intersection_index].first );
  output.close();
  //delete result polyhedra when no longer needed
  delete result[0].first;
  delete result[1].first;
  return 0;
