- To: <>
- Subject: [cgal-discuss] Is it possible to intersect polyhedrons with AABB_tree ?
- Date: Thu, 19 Nov 2015 18:16:19 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:UHv+shKQ4FeCF2vwKtmcpTZWNBhigK39O0sv0rFitYgUKf7xwZ3uMQTl6Ol3ixeRBMOAu68C1bGd4v2ocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWC0oLpjKvjptX6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86Fpy8kVBa71dqB9Qb1DByk9KEg04tfqvF/NV13cyGEbVzAWlQdTGAXDpEX6WYrqqSb8nutl1zHcM9egHuN8Yiir86o+EEygsywALTNsqGw=
Hello,
For now I end up with this code, but impossible to compile the last line of the main !...
Can somebody give me some clue / help on this ?
Franck# Created by the script cgal_create_cmake_script
# This is the CMake script for compiling a CGAL application.
project( 02.cgal_ )
cmake_minimum_required(VERSION 2.8.10)
find_package(CGAL QUIET COMPONENTS Core ) # CGAL 4.7
if ( CGAL_FOUND )
include( ${CGAL_USE_FILE} )
include( CGAL_CreateSingleSourceCGALProgram )
create_single_source_cgal_program( "intersect.cpp" )
else()
message(STATUS "This program requires the CGAL library, and will not be
compiled.")
endif()
#include <CGAL/Exact_predicates_exact_constructions_kernel.h> #include <CGAL/Point_3.h> #include <CGAL/Polyhedron_3.h> #include <CGAL/AABB_tree.h> #include <CGAL/AABB_traits.h> #include <CGAL/AABB_segment_primitive.h> #include <CGAL/AABB_face_graph_triangle_primitive.h> #include <list> typedef CGAL::Exact_predicates_exact_constructions_kernel Kernel; typedef CGAL::Point_3<Kernel> Point_3; typedef CGAL::Polyhedron_3<Kernel> Polyhedron_3; typedef Polyhedron_3::Vertex_const_iterator Polyhedron_3_Vertex_iterator; typedef CGAL::AABB_face_graph_triangle_primitive<Polyhedron_3> Polyhedron_3_Primitive; typedef CGAL::AABB_traits<Kernel, Polyhedron_3_Primitive> Polyhedron_3_Traits; typedef CGAL::AABB_tree<Polyhedron_3_Traits> Polyhedron_3_Tree; typedef Polyhedron_3_Tree::Object_and_primitive_id Polyhedron_3_Object_and_primitive_id; int main () { Polyhedron_3 P; Point_3 P1 (-1, -1, 0); Point_3 P2 ( 1, -1, 0); Point_3 P3 ( 1, 1, 0); Point_3 P4 (-1, 1, 0); P.make_triangle (P1, P2, P3); P.make_triangle (P1, P3, P4); Polyhedron_3 Q; Point_3 Q1 (0, 0, 0); Point_3 Q2 (2, 0, 0); Point_3 Q3 (2, 2, 0); Point_3 Q4 (0, 2, 0); Q.make_triangle (Q1, Q2, Q3); Q.make_triangle (Q1, Q3, Q4); Polyhedron_3_Tree poly_tree(CGAL::faces(P).first, CGAL::faces(P).second, P); poly_tree.accelerate_distance_queries(); std::list<Polyhedron_3_Object_and_primitive_id> intersect_polys; //poly_tree.all_intersections(Q, std::back_inserter(intersect_polys)); return 0; }
- [cgal-discuss] Is it possible to intersect polyhedrons with AABB_tree ?, houssen, 11/19/2015
- Re: [cgal-discuss] Is it possible to intersect polyhedrons with AABB_tree ?, Sebastien Loriot (GeometryFactory), 11/19/2015
