- To:
- Subject: [cgal-discuss] Point precision
- Date: Thu, 26 Nov 2015 13:29:14 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:XvSuJR1P9KbOq/57smDT+DRfVm0co7zxezQtwd8ZsegTK/ad9pjvdHbS+e9qxAeQG96LtrQU06GN7ejJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6kO74TNaIBjjLw09fr2zQd6PyZTvnLvss7ToICx2xxOFKYtoKxu3qQiD/uI3uqBFbpgL9x3Sv3FTcP5Xz247bXianhL7+9vitMU7q3cY6Lod8JtLXqz+Oqg5VrdFFy8OMmYv5cStuwOQYxGI4y4kVWEhtx1OGJPy1AzgQhLGkib+t+90wGHOJcryC7UzXy+lx6dmTB7tgT9BPD5vozKfsdB5kK8O+EHpnBd42YOBOIw=
I am retrieving the coordinates x,y,z from a xyz file to compute a delaunay. The values have double precision.
If I print or save the values of a point, x and y have no longer double precision, but the z does. I've debugged the program and if I add a watch _expression_ as *(double*)<address of the x> I get the original, correct double value.I am using
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Projection_traits_xy_3<K> Gt;
typedef CGAL::Triangulation_vertex_base_2<Gt> Vb;
typedef CGAL::Delaunay_mesh_face_base_2<Gt> Fb;
typedef CGAL::Triangulation_data_structure_2<Vb, Fb> Tds;
typedef CGAL::Constrained_Delaunay_triangulation_2<Gt, Tds> CDT;
Thanks!
- [cgal-discuss] Point precision, Pol Monsó Purtí Helimap, 11/26/2015
- Re: [cgal-discuss] Point precision, Sebastien Loriot (GeometryFactory), 11/26/2015
- Re: [cgal-discuss] Point precision, Pol Monsó Purtí Helimap, 11/26/2015
- Re: [cgal-discuss] Point precision, Daniel Duque, 11/26/2015
