cgal-discuss - [cgal-discuss] What's the difference between the "face" and "facet" in Class TriangulationDataStructure
  • To:
  • Subject: [cgal-discuss] What's the difference between the "face" and "facet" in Class TriangulationDataStructure
  • Date: Wed, 25 Nov 2015 09:41:53 -0800 (PST)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Fail ; spf=None
  • Ironport-phdr: 9a23:7WtXCRZXD6r/75Oc9fMwwyv/LSx+4OfEezUN459isYplN5qZpci8bnLW6fgltlLVR4KTs6sC0LqL9f+wEjVYv96oizMrTt9lb1c9k8IYnggtUoauKHbQC7rUVRE8B9lIT1R//nu2YgB/Ecf6YEDO8DXptWZBUiv2OQc9HOnpAIma153xjLDvvcKDKFwQ2nKUWvBbElaflU3prM4YgI9veO4a6yDihT92QdlQ3n5iPlmJnhzxtY+a9Z9n9DlM6bp6r5YTGZPTJPppCOUARHR9azh0t4XXskzIQgKLo3cdSW4LiQFgAg7f7Ri8UI2inDH9s79X4hiTO8K+GaE+Qxyy6rotRRP1ziwBYW1quFrLg9B92fsI6CmqoAZyltWMOIw=
Hi, everyone.
I have a Delaunay Triangulation, say DT. The points used for the Delaunay
Triangulation are the vertices of a triangle mesh T. And I would like to get
all the tetrahedrons of DT which are incident to a face S of the triangle
mesh. Any idea of doing that?
And I am still confused about the definitions of "face" and "facet" in
Class TriangulationDataStructure. The "facet " means the faces of the
tetrahedrons or the faces of the triangle mesh?
Thank you.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/What-s-the-difference-between-the-face-and-facet-in-Class-TriangulationDataStructure-tp4661397.html
  • [cgal-discuss] What's the difference between the "face" and "facet" in Class TriangulationDataStructure, BRYang, 11/25/2015
