- To:
- Subject: Re: [cgal-discuss] concurrency for Constrained_Delaunay_triangulation_2
- Date: Thu, 26 Nov 2015 16:28:21 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:c6Y0xRMS1nGVoFk07DQl6mtUPXoX/o7sNwtQ0KIMzox0Kfz/rarrMEGX3/hxlliBBdydsKIZzbqO+P+7EUU7or+/81k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i760zceF13FOBZvIaytQ8iJ35nxh7j5pMabSj4LrQT+SIs6FA+xowTVu5teqqpZAYF19CH0pGBVcf9d32JiKAHbtR/94sCt4MwrqHwI6Lpyv/NGSrjwKqQkUaRDXnNhKHEw/MSttB/ZTALJ6GFbSXQTihMPAg7L61bxUZ719yf7reFgwzLJAcqjRr89XXGu7rxgVQTzoCYBLT8wtm/N2eJqi6cOmBWlkDl4xZVPV7mILub7SYPQedIfTHIJCt5WU2pEBYWnaKMPAu4AOO9A6YL98Qhd5SCiDBWhUbu8ggRDgWX7iPU3
Could you elaborate a littlebit?
I have the points stored in memory.
Is it possible to compute
CDT cdt;cdt.insert(points.begin(), points.end());
(if there's another way to insert the points, welcome!)
To speed up the computation for large datasets on a i7.
cheers,
Pol
On Thu, Nov 26, 2015 at 4:22 PM, Andreas Fabri <> wrote:
Operations that do not modify the triangulation are ult-threading safe.
andreas--
On 26/11/2015 16:20, Pol Monsó Purtí Helimap wrote:
Does Constrained_Delaunay_triangulation_2 have concurrency available?
- [cgal-discuss] concurrency for Constrained_Delaunay_triangulation_2, Pol Monsó Purtí Helimap, 11/26/2015
- Re: [cgal-discuss] concurrency for Constrained_Delaunay_triangulation_2, Andreas Fabri, 11/26/2015
- Re: [cgal-discuss] concurrency for Constrained_Delaunay_triangulation_2, Pol Monsó Purtí Helimap, 11/26/2015
