cgal-discuss - Re: [cgal-discuss] concurrency for Constrained_Delaunay_triangulation_2
  • To:
  • Subject: Re: [cgal-discuss] concurrency for Constrained_Delaunay_triangulation_2
  • Date: Thu, 26 Nov 2015 16:31:37 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-phdr: 9a23:xmoygBflGLZtdQFzxkFX2oKYlGMj4u6mDksu8pMizoh2WeGdxc+6Yx7h7PlgxGXEQZ/co6odzbGG7uawASdfut6oizMrTt9lb1c9k8IYnggtUoauKHbQC7rUVRE8B9lIT1R//nu2YgB/Ecf6YEDO8DXptWZBUiv2OQc9HOnpAIma153xjLDvvc2LKFoTzBOGIppMbzyO5T3LsccXhYYwYo0Q8TDu5kVyRuJN2GlzLkiSlRuvru25/Zpk7jgC86l5r50IAu3Heb8lR+lYECg+KDJyo9b6sAHKCwqJ/HoVFGsM1QFZBhDMqxD8UJC2uSTzsq9x2TKRINbtHowzDD+t5qMuRB7zgzocLBY49nvWg4p+lvF1uhWk8jV5z5TZaZrdGvN0ZKKVKdocSXBMV90XWSVLGIKUYIYICucdJ/dWpoLhoEEf6xC5AF//V6vU1jZUiyqujuUB2OM7HFSe0Q==
The construction is not parallelized.
This is so far only done for the 3D triangulation
and the tetrahedral mesh generator.
Andreas
On 26/11/2015 16:28, Pol Monsó Purtí Helimap wrote:
Could you elaborate a littlebit?
I have the points stored in memory.
Is it possible to compute
CDT cdt;
cdt.insert(points.begin(), points.end());
concurrently?
(if there's another way to insert the points, welcome!)
To speed up the computation for large datasets on a i7.
I couldn't find the Concurrency_tag on this one.
cheers,
Pol
On Thu, Nov 26, 2015 at 4:22 PM, Andreas Fabri
<mailto:>>
wrote:
Operations that do not modify the triangulation are ult-threading safe.
andreas
On 26/11/2015 16:20, Pol Monsó Purtí Helimap wrote:
Does Constrained_Delaunay_triangulation_2 have concurrency
available?
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
