- To:
- Subject: Re: [cgal-discuss] Kd_tree move constructible
- Date: Thu, 26 Nov 2015 20:03:59 +0100 (CET)
On Thu, 26 Nov 2015, Laurent Rineau (CGAL/GeometryFactory) wrote:
Le Wednesday 25 November 2015 18:52:03 Marc Glisse a ?crit :
On Wed, 25 Nov 2015, Bart Vermeulen wrote:
I'm trying to use c++11 threads with a Kd_tree.
I have a function which takes a Kd_Tree as input:
void foo (Tree const & tree, ...) {
// Do something
Than I try to pass the function to a std::thread construction:
std::thread thethread(foo, tree, ...);
This gives me an error telling me that the constructor Kd_tree(const Tree&
tree) is private.
The std::thread construction requires all parameters to be move
constructible, but why is this construction private for a Kd_tree?
Is there some way around this issue?
http://en.cppreference.com/w/cpp/utility/functional/reference_wrapper
I solved the issue passing a pointer to the tree, instead of a reference.
Still I think it's strange that the copy construction is made private in
Kd_tree.
How often do you actually want a copy of a kd-tree? If you are doing the
copy by accident, or because you don't know the right syntax, it is good
that you get some error about it.
But should not the CGAL develop try to allow the move constructor, when the
copy constructor is disabled?
Yes, sure, feel free to implement it (this private, not-quite-copy constructor (Tree != Self) that doesn't actually copy the data is a bit strange, by the way). But in the OP's case, it seems much more likely that using a reference is the best option. Also, moving would require passing an explicit std::move(tree).
About Kd_tree, if we are going to add features, I'd be much more interested in functions to add or remove points (mostly remove, actually) without having to recompute the whole data-structure (even if subsequent searches have sub-optimal complexity).
Marc Glisse
- [cgal-discuss] Kd_tree move constructible, Bart Vermeulen, 11/25/2015
- Re: [cgal-discuss] Kd_tree move constructible, Bart Vermeulen, 11/25/2015
- Re: [cgal-discuss] Kd_tree move constructible, Marc Glisse, 11/25/2015
- Re: [cgal-discuss] Kd_tree move constructible, Laurent Rineau (CGAL/GeometryFactory), 11/26/2015
- Re: [cgal-discuss] Kd_tree move constructible, Marc Glisse, 11/26/2015
