- To:
- Subject: Re: [cgal-discuss] Using Plane_3 as key in a std::map
- Date: Tue, 8 Dec 2015 21:24:50 +0530
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:/vGjaBJQY1MIQhyZrtmcpTZWNBhigK39O0sv0rFitYgUIvXxwZ3uMQTl6Ol3ixeRBMOAu6wC07KempujcFJDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBXsq3G/pQQfBg/4fVIsYL+lRMiK14ye7KObxd76W01wnj2zYLd/fl2djD76kY0ou7ZkMbs70RDTo3FFKKx8zGJsIk+PzV6nvp/jtM0rziJLpvh099JcSb6oOOMjXLlABXInNXo07Yvlr17YXA6X7zwdVGsR1RFHCgyA4BDhVYrqqXjGsb921yCeeMH3VrspQi+K7qFxSRauhj1UGSQ+9TTYl8prjKMTrw+5uxU3l4HJZpqVNfVjZr/ULPsVQGNAWoBaUCkXUdD0VJcGE+dUZbUQlIL6vVZb9RY=
typedef CGAL::Lazy_exact_nt<CGAL::Gmpq> NT;
typedef CGAL::Simple_cartesian<NT> K;//tried with Extended cartesian as well
typedef K::Point_3 Point3;
typedef K::Plane_3 Plane3;
std::map<Plane3, int,CGAL::Plane_lt> planes;
planes[Plane3(Point3(12,0,0),Point3(0,6,0),Point3(0,0,8))]=2;
std::cout<<planes[Plane3(Point3(6,3,0),Point3(0,3,4),Point3(6,0,4))];
//output: 0
//Plane3(Point3(6,3,0),Point3(0,3,4),Point3(6,0,4))==Plane3(Point3(12,0,0),Point3(0,6,0),Point3(0,0,8)) returns true
On Tue, 8 Dec 2015, vimarsh wrote:
I wanted to use a Plane_3 as the key value in a std::map, so i passed the
third argument to the map as:
typedef CGAL::Extended_cartesian<NT> K;
typedef K::Plane_3
Plane3;
It does not work if i just do std::map<Plane3,int>,(so i guess it is not
derived from LessComparable), and i tried passing CGAL::Plane_lt as the
third argument, but later realised that is only for RingType while my kernel
uses a FieldType.
Uh? A field is a ring. Could you show a minimal program and the error you got?
How can i achieve what i want with my kernel?
(I also tried replacing the RT with FT, after copying how Plane_lt is
defined, in my code, but that didn't work either )
"doesn't work" doesn't help.
Marc Glisse
- [cgal-discuss] Using Plane_3 as key in a std::map, vimarsh, 12/08/2015
- Re: [cgal-discuss] Using Plane_3 as key in a std::map, Marc Glisse, 12/08/2015
- Re: [cgal-discuss] Using Plane_3 as key in a std::map, gunshi gupta, 12/08/2015
- Re: [cgal-discuss] Using Plane_3 as key in a std::map, vimarsh, 12/08/2015
- Re: [cgal-discuss] Using Plane_3 as key in a std::map, Andreas Fabri, 12/08/2015
