cgal-discuss - Re: [cgal-discuss] Using Plane_3 as key in a std::map
  • To:
  • Subject: Re: [cgal-discuss] Using Plane_3 as key in a std::map
  • Date: Tue, 8 Dec 2015 08:47:45 -0800 (PST)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
  • Ironport-phdr: 9a23:d8XNihbJ/1BUg91KeTBS28X/LSx+4OfEezUN459isYplN5qZpc6ybnLW6fgltlLVR4KTs6sC0LqI9fi4EUU7or+/81k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i760zceF13FOBZvIaytQ8iJ35rxj7j60qaQSjsLrQL1Wal1IhSyoFeZnegtqqwmFJwMzADUqGBDYeVcyDAgD1uSmxHh+pX4p8Y7oGwD884mosVPWKG/c6UjRqFDFxwnNXo07Yvlr0rtVwyKs2UdV2wMiRoAVxbE6RjgRZe3uQP1s+N83G+ROsigHuN8Yiir86o+EEygsywALTNsqGw=
Okay, i will keep that in mind.
gist:
https://gist.github.com/vimarshc/d4b76f7144c8605ca862
<https://gist.github.com/vimarshc/d4b76f7144c8605ca862>
According to me, the error is the unexpected output, since if the map is
successfully using Plane3 as a key, it should give the output '2' instead of
'0', since
Plane3(Point3(12,0,0),Point3(0,6,0),Point3(0,0,8))==Plane3(Point3(6,3,0),Point3(0,3,4),Point3(6,0,4))
returns true since they're the same plane and i use an exact constructions
kernel, and i've already inserted it into the map with corresponding value
'2'.
Thanks!
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Using-Plane-3-as-key-in-a-std-map-tp4661450p4661456.html
