cgal-discuss - Re: [cgal-discuss] Linear cell complex: function are_facets_same_geometry not working
  • To:
  • Subject: Re: [cgal-discuss] Linear cell complex: function are_facets_same_geometry not working
  • Date: Mon, 4 Jan 2016 10:12:08 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-phdr: 9a23:8TsSRhKBmtLXNKoftdmcpTZWNBhigK39O0sv0rFitYgUL/zxwZ3uMQTl6Ol3ixeRBMOAu6wC07KempujcFJDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBXsq3G/pQQfBg/4fVIsYL+lRMiK14ye7KObxd76W01wnj2zYLd/fl2djD76kY0ou7ZkMbs70RDTo3FFKKx8zGJsIk+PzV6nvp/jtM0rzyMFsP0o84tMUL7xYr8jZb1eFjUvdW4vt+PxshyWYhaO4n8VT2Ab2jZBBgnM6h2yCpjssy/+v/d41W+WNMj3RLY4cTCj9aZwDhTukjxBOSRvozKfsdB5kK8O+EHpnBd42YOBOIw=
Hi Pranav,
This (unofficial and undocumented) function tests if the two dart handles point to two faces having the same geometry but with reverse orientations.
Best regards
Guillaume
Le 04/01/2016 09:48, Pranav a écrit :
Hi,
Function /are_facets_same_geometry/ seems to be not working. I tried to
create a linear cell complex containing a single triangle. While attempting
to call this function with dart handle to this triangle as both arguments,
it returns false. Following is the link to a simple test code:
https://gist.github.com/pranavkantgaur/ddc18fe6a9d04c11af55#file-testfacetgeometry-cpp
With regards,
Pranav
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Linear-cell-complex-function-are-facets-same-geometry-not-working-tp4661476.html
Guillaume DAMIAND
CNRS - LIRIS UMR 5205
Université Claude Bernard
Bâtiment Nautibus (710)
43 Boulevard du 11 Novembre 1918
69622 Villeurbanne Cedex (France)
Tél: +33 (0)4.72.43.14.34 Fax: +33 (0)4.72.43.15.36
Mail:
Web: http://liris.cnrs.fr/guillaume.damiand/
Attachment: smime.p7s
Description: Signature cryptographique S/MIME
