cgal-discuss - [cgal-discuss] Linear cell complex: function are_facets_same_geometry not working
  • To:
  • Subject: [cgal-discuss] Linear cell complex: function are_facets_same_geometry not working
  • Date: Mon, 4 Jan 2016 00:48:17 -0800 (PST)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
  • Ironport-phdr: 9a23:xkVc3BfMR8BSve/wQRDAO7aWlGMj4u6mDksu8pMizoh2WeGdxc6+YR7h7PlgxGXEQZ/co6odzbGG7ea4ASQp2tWojjMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpQAbFhi3DwdpPOO9QteU1JTpkbjqs7ToICx2xxOFKYtoKxu3qQiD/uI3uqBFbpgL9x3Sv3FTcP5Xz247bXianhL7+9vitMU7q3cYjdt6qZ8FCP2yP/9gFf0LRAghZms67cmuuRjYRhaU/VMdVH8Xm1xGGVvr9hb/C6/ruy3zqKIpwDOTO8ToHbE1Qj+K4KJiSRuugyACYW1quFrLg9B92fsI6CmqoAZyltWMOIw=
Hi,
Function /are_facets_same_geometry/ seems to be not working. I tried to
create a linear cell complex containing a single triangle. While attempting
to call this function with dart handle to this triangle as both arguments,
it returns false. Following is the link to a simple test code:
https://gist.github.com/pranavkantgaur/ddc18fe6a9d04c11af55#file-testfacetgeometry-cpp
With regards,
Pranav
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Linear-cell-complex-function-are-facets-same-geometry-not-working-tp4661476.html
