- To:
- Subject: Re: [cgal-discuss] Coding Conventions - CGAL methods VS custom implementations
- Date: Mon, 18 Jan 2016 07:35:21 +0100 (CET)
On Sun, 17 Jan 2016, s_gandhi wrote:
Please find the code in the attached file named "Custom_vs_CGAL_speed.cpp".
Also find the screenshot of timings on my machine, named "cgal_speeds_1.png"
I am using EPIC,
so should I implement the stuff myself? It gives me better timings.
And if I compare any CGAL's examples with my implementation, I (am) will be
faster.
You should benchmark against Simple_cartesian<double>, not Epick, since you don't seem to aim for exactness.
Please read the link I gave in the previous email and understand that your code will sometimes give the wrong result, which is why we cannot use it in Epick.
Marc Glisse
- [cgal-discuss] Coding Conventions - CGAL methods VS custom implementations, s_gandhi, 01/15/2016
- Re: [cgal-discuss] Coding Conventions - CGAL methods VS custom implementations, Marc Glisse, 01/15/2016
- Re: [cgal-discuss] Coding Conventions - CGAL methods VS custom implementations, s_gandhi, 01/15/2016
- Re: [cgal-discuss] Coding Conventions - CGAL methods VS custom implementations, s_gandhi, 01/18/2016
- Re: [cgal-discuss] Coding Conventions - CGAL methods VS custom implementations, Marc Glisse, 01/18/2016
- Re: [cgal-discuss] Coding Conventions - CGAL methods VS custom implementations, Sagar Gandhi, 01/19/2016
